I used a simple screwdriver with a hammer, did the bottom one first, the bearing race sits inside the lower neck up against a lip, you may be hitting on that lip instead of the race..
look down inside with a good light, you should see the race clearly (wipe the grease off it first), then with trusty screwdriver and hammer work your way round the race with a few well placed hits, may take a few to get it out.
then do the same for the top one..
If you have sealed bearings, and they are stuck, they must have been done up really tight
