Thank you to everyone for all of your feedback. I apologize for not getting on here earlier, but have found it tough to put some time into the bike prior to writing. Now, I've finally cleaned carbs 1 and 2 and kept a lot of your advice in mind.
Goldarrow, thanks for the salocal link. That tutorial was great and I'm thinking the torque specs will come in very handy in the future.
BobbyR, thanks for the advice on using copper wire to rod out the jets. So far, I've been using the nylon bristles from the bottom of a push broom and it's actually worked quite well. I have seen light through all of the circuits, so it's quite likely that they weren't that gummed up. This doesn't sound like the near chiselling you've had to do in the past, but who knows what surprises will await in carbs 3 and 4. I might still be buying some 30ga. copper wire - does that size sound about right?
Harisuluv, I appreciate the offer to sodablast the carb bodies for only $60, which seems like a great deal with shipping in, but I really wanted to just get going using the chem-dip I bought. I am a special kind of cheapskate that needs to extract maximum value from all purchases whenever possible, so hopefully I don't regret this choice. The bodies look okay to me, but you may notice a difference from the satin OEM finish once I actually upload pics (soon, I promise).
Johnie, you read my mind with the pictures comment. I borrowed my dad's tripod and set it up next to the bench to take pics of all parts and different stages. With that said, I should probably be taking photos more frequently.
I only pulled carbs 1 and 2 apart at this point so that I have a few properly assembled examples in case I can't figure out reassembly on my own. I did the baggie trick too, separating each carburetor and its internals into corresponding baggies. Good ideas!
Lucky, thanks for the tip on no overnights in the chem-dip. I did 2 hours for carb 1 and 2.25 hrs for carb 2, which seems to have been sufficient, but had flirted with the idea of overnights prior to reading your advice.
Aintnoeasyway, I sure appreciated the theory from Honda, that was a great link and some great reading for a carb newb. I'll visit that page many a time I'm sure.
A few of you pointed out that eye protection might be a good idea - I went a step further and wore a mask and gloves too. Berryman's chem-dip seems plenty potent to me so I didn't want to mess around and it seemed like a good idea around compressed air and now a can of aerosol carb cleaner as well. Good advice!
One more question, then I'll stop typing. I've read in the past that after you're done in the chem-dip, you should rinse the carbs in water. This seems a bit strange to me after removing all the mineral deposits from gasoline and other gunk. I opted to simply blow the different ports, jets, body, etc. with one of those computer keyboard compressed air cleaners (still haven't sold my wife on a good air compressor and pneumatic tools). They look pretty good, but does this sound to you guys like I'm cutting a crucial step? Just thinking about my air cans not being that powerful or plentiful, and water left anywhere on the carb or internals must be a bad thing...
Thanks again everyone!
Tom
