Author Topic: MotoGPWerks Pipe CB550 (Jetting and video)  (Read 50233 times)
Offline Tews19
  • I am no
Re: MotoGPWerks Pipe CB550 (Jetting and video)
« Reply #175 on: May 22, 2015, 12:29:27 PM »
Thanks Fly, pulling the carbs now.
1970 Honda CB750 survivor.
Offline mrfish2
  • I might be a
« Reply #176 on: May 22, 2015, 12:33:08 PM »
if the fuel level changes(rises) slowly after you start the test, you have a float valve dysfunction
So if you have brand new float valves and float needles installed and it's still doing this, then what would you do to remedy it?
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #177 on: May 22, 2015, 12:39:12 PM »
change the float height   ;D
float height is not the goal.  correct fuel LEVEL is  ;)
« Reply #178 on: May 22, 2015, 12:42:04 PM »
(Assuming) he measured the floats (and adjusted if needed) to verify the proper height, Tews19's results above back up why this is a valid test.
Especially with new/aftermarket float needle sets, you cant just ride off thinking you're good.  His #4 could have starved that cyl for fuel and run really hot to the point of failure.
« Last Edit: May 22, 2015, 12:50:08 PM by flybox1 »
Offline stewonepot
« Reply #179 on: May 22, 2015, 12:50:31 PM »
hi look into the float bowl vents maybe a blockage
regards Stew
Offline Tews19
  • I am no
« Reply #180 on: May 22, 2015, 02:02:52 PM »
I have a set of unmolested carbs from this bike. Original owner never opened them up. I'm going to swap floats and see how that turns out. If spot on I will leave the floats in. If off I will put the original floats to this carb set back in and adjust per Flybox's advice. Can't beat the assistance here!
« Reply #181 on: May 22, 2015, 02:06:58 PM »
I wouldnt bother.  Adjust yours and retest.
Arent the ones in your carbs OEM's as well?
Offline Tews19
  • I am no
« Reply #182 on: May 22, 2015, 02:09:22 PM »
True. I will adjust and yes OEM.
Offline Tews19
  • I am no
« Reply #183 on: May 22, 2015, 03:34:37 PM »
What a PITA. Been trying #4 all afternoon. It just won't go any higher.
Offline Tews19
  • I am no
« Reply #184 on: May 22, 2015, 03:53:14 PM »
Freaking hilarious. After my post. I adjust again and now it's spot on.
« Reply #185 on: May 22, 2015, 04:24:23 PM »
Beers all around!!!!!! ;D
Offline Tews19
  • I am no
« Reply #186 on: May 22, 2015, 05:20:00 PM »
Thanks man! I got 3 of 4 carbs done. My hands have stopped working so I will finish tomorrow. Thanks again fly. Where are you located?
« Reply #187 on: May 22, 2015, 05:26:56 PM »
Glad you're getting close. ;D
I'm about 30 min N of Seattle.
Offline Tews19
  • I am no
« Reply #188 on: May 22, 2015, 07:55:36 PM »
Oh that's a great area. I was stationed at Ft. Lewis from 01-05. Very expensive area for houses.
« Reply #189 on: May 22, 2015, 08:15:33 PM »
Haha, sweet.  By '08, you coulda had twice the house for half the price ;). Certainly not that way anymore.
I'll be down at JBLM (Joint Base Lewis McChord) next weekend for my kids track meet.
Offline Tews19
  • I am no
« Reply #190 on: May 25, 2015, 01:22:08 PM »
Got all floats level and sync'd the carbs. Bike is rich as can be so I will most likely use 2 or more sets of new plugs. D7EA plugs currently.
Offline riverfever
« Reply #191 on: May 25, 2015, 07:17:07 PM »
Tews my levels were higher than that and I dropped them a lot. Mine are now about 3mm below the flange that the screws sit on. After making that adjustment, I finally was able to keep all 4 cylinders running and not foul out plug 4.
Offline Tews19
  • I am no
« Reply #192 on: May 25, 2015, 07:29:04 PM »
Interesting. I'm fouling the #$%* out of these. Bought 3 new sets of plugs. Rode to a place where I could do a plug chop. My slow jets need to be swapped out. Way to rich. May have to order a.set of 40s. Running 42 now.
Offline riverfever
« Reply #193 on: May 25, 2015, 07:38:24 PM »
I just deleted all the pics I had while doing the clear tube off my phone. This is damn near where all of mine ended up. I think I finally had the floats set at 27mm but I really had to mess with #4 to get it the same as the rest. I just forgot about measuring it and kept making adjustments until I finally had it inline with the others. What was interesting was that all last summer I ran on three cylinders (1-3). Like I said in my thread...this is the first time 4 has hung in there. I probably have 30 plugs laying around.
Offline Tews19
  • I am no
« Reply #194 on: May 25, 2015, 07:45:44 PM »
I'm at 12 plugs as of today alone. Is it possible to make a video of it running and when you hit the flat spot? I'm almost positive we have the same issue going. Today mine was so rich the bike was bogging down. But as you stated, if you stay on the throttle it will take off after the bogging down.
Offline mrfish2
  • I might be a
« Reply #195 on: May 25, 2015, 07:55:15 PM »
Why not go back to the stock 38's? From what I've read from other threads as long as the air induction system hasn't changed (i.e. stock airbox vs pods) then you shouldn't need anything other than stock size idle jets.
1980 CB650C - Sold
Offline riverfever
« Reply #196 on: May 25, 2015, 07:55:47 PM »
Mine's not doing it nearly as badly now after messing with the needles again but I thought about trying to get a video. If it's not raining or snowing when I get home tomorrow I'll try.
Offline riverfever
« Reply #197 on: May 25, 2015, 08:06:04 PM »
Isn't 40 stock?
Offline Tews19
  • I am no
« Reply #198 on: May 25, 2015, 08:08:47 PM »
38s are stock for 069a carbs.
Offline gregripko
« Reply #199 on: May 25, 2015, 08:30:48 PM »
Best setup for me was to keep slow jet at #38 and just upped the mains to #105... Runs good
