Author Topic: Wheel Spacer Ideas...  (Read 756 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: August 30, 2013, 07:03:17 PM »
I'm using a different rear wheel on my project and need a smaller spacer. Can I just cut down the original one as long as the sprocket side stays in the same spot ?
Offline jamesb
Re: Wheel Spacer Ideas...
« Reply #1 on: August 30, 2013, 07:25:55 PM »
I had some originals turned down on a metal lathe on the brake side and never had any problems with it did the same on the front end too.
Offline robdrobd
  • Who? Me?
« Reply #2 on: August 30, 2013, 08:17:59 PM »
If I only has a metal lathe.. ???
Offline bjbuchanan
« Reply #3 on: August 30, 2013, 09:27:07 PM »
Technically you could do it with a grinder and files. You just gotta be attentative and not limp wristed with that grinder.
It is a meaty piece and you would want to get relatively tight to your measurement you need. NASA specifications not necessary but getting pretty on is. Go for it, I would.
I would use my grinder, then my dremel and then files to knock down stuff and make it nicer for the appearance
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #4 on: August 30, 2013, 10:04:40 PM »
Or take it to a local machine shop with the required dimension.  Should be at least a ten minute job for somebody.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
« Reply #5 on: August 30, 2013, 10:27:44 PM »
The shorter they are, theharder to fit in a lathe..
 If you use a grinder and calipers, or a small square, and file you can. Get it good enough.
