Author Topic: weird ignition problem  (Read 1609 times)
Offline joemcvw1951
« on: September 02, 2013, 08:39:06 PM »
Bike started losing power, got home stumbling & bogging. Checked the points and timing, looks good , I can see spark on the poinst. I don't seem to be getting any spark to the 2-3 cylinders though, any ideas what to check next ?
Thanks
Offline MoMo
  • Ride like you're invisible
Re: weird ignition problem
« Reply #1 on: September 02, 2013, 10:57:27 PM »
I have seen quite a few similar situations(seems to spark at points but no spark at plugs) turn out to be dirty points.  Use a point file, electronic cleaner and air.  I have a few emery files left(very similar to a women's nail file) that I use.  File between points, spray cleaner, several back and forth passes, remove file, hold points open and  use air to blow away any residue...Larry
Offline joemcvw1951
« Reply #2 on: September 03, 2013, 04:03:44 AM »
Tried that, I have some emery paper, didn't make a difference :-( , could it be wiring or shorting or a bad coil ?
Offline joemcvw1951
« Reply #3 on: September 03, 2013, 04:04:29 AM »
ps, the points are just replaced, brand new
Offline MoMo
« Reply #4 on: September 03, 2013, 06:02:16 AM »
Model and year?  Check the connection coming from the points.  Had a 750 once where the bullet connector by the frame was not tight so spark was intermittent...Larry
Offline joemcvw1951
« Reply #5 on: September 03, 2013, 06:08:25 AM »
1974 CB550
Offline Vincent P
« Reply #6 on: September 03, 2013, 06:26:43 AM »
Check the condenser for 2/3 points.
1973 Honda CB750 K3
Offline joemcvw1951
« Reply #7 on: September 03, 2013, 10:23:49 AM »
checked the consor and found that the yellow power wire was broken at the blade terminator, fixed and working well now, thanks
Offline MoMo
« Reply #8 on: September 03, 2013, 11:19:23 AM »
good job...Larry
Offline Vincent P
« Reply #9 on: September 03, 2013, 11:53:50 AM »
Awesome!!!
1973 Honda CB750 K3
Offline joemcvw1951
« Reply #10 on: September 03, 2013, 01:34:10 PM »
Thanks for everyones help
