Yeah, thanks for the replies. I suspect that it is something to do with the float bowl heights and plan on rechecking them. As for the front brake, well I disassembled it completely and re-greased everything from cables down to the cams and bearings, even cleaning out the brake dust and ruffing up the pads and linings. Still I can't get the brake lever to retract completely. I see that the cams have two dots: one on the gnarled, exterior part of the cams and the other on the drum brake housing. They are markers used to make sure that the cams are aligned properly. How does the adjusting pushrod connecting the leading to the trailing brake effect performance? I would assume that by using more pushrod the trailing brake sticks out farther but I couldn't confirm that when trying to do so in my garage. I wanted to set the brakes to where they were barley touching the linings statically and then back them off again. Instead, I could never get them to bite and the only way that it appeared I could do so was to not align the punched holes on the cams and the housing. I'd like the brakes to bite earlier and get them to recoil so as not to let the brake drag slightly after use.
