Author Topic: Slipping out of 5th (when clicking in)  (Read 1098 times)
Offline SKTP
« on: September 03, 2013, 01:24:14 PM »
Sorry everyone, dragging this issue up again (for me)...
Symptoms:
So the Bike has been completely rebuilt by me. First engine/tranny rebuild ever for me. The bike has new rings/seals/gaskets and a donor tranny from ebay.
First to fourth all shift and stay in gear perfectly. Fifth however all ways drops out into a high-reving "false neutral" sort of place...I can click it back down into 4th (which then stays in 4th normally) or click it back up into 5th where it will either stay for a bit or drop out again and then I repeat clicking up until it stays...It usually drops out again....
After talking to Kurt at Valley Cycles, he thought if I am lucky it could be a clutch-slipping issue...I am hopign it it, as I do not want to split the cases if I don't have to...What would be your advise/next step?
I will try readjusting the clutch and crossing my fingers
I am running MOTUL 5100 10W40 (break in/non-synthetic)
The bike has 130miles on it since rebuild
Thank you for any ideas
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: Slipping out of 5th (when clicking in)
« Reply #1 on: September 03, 2013, 02:47:36 PM »
Major clutch slippage should be felt in the lower gears also if that was the case.
Black 750K8
« Reply #2 on: September 03, 2013, 03:22:33 PM »
I agree the clutch would slip in all gears. You have a problem with the tranny or linkage.
Offline SKTP
« Reply #3 on: September 03, 2013, 03:23:36 PM »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #4 on: September 03, 2013, 03:46:47 PM »
When you swapped trannies did you swap the whole assembly's or did you take the shafts apart and change just bad gears? Did you have a trans problem before and that's why you changed it out.Which shift forks did you use,the ones from your old tranny or a different pair that came with the 'new' one? 2nd gear is problem with the dogs as I think 4th gear also and are more common. Maybe good ole' Hondaman can school us a little on 5th gear problems. Where is our Superhero  :)
Offline SKTP
« Reply #5 on: September 03, 2013, 03:54:41 PM »
I swapped out everything...the original tranny was clearly grinding on itself and showed signs of obvious wear (and didn't work) it was jammed in permanent 2nd
Fork wear seen here (these were replaced)
http://i297.photobucket.com/albums/mm202/ChristopherBywater/teardown%20008/download.jpg
Lots of old tranny pics here
http://forums.sohc4.net/index.php?topic=68423.50
New (swapped) tranny here
http://forums.sohc4.net/index.php?topic=68423.250
Here's the last picture I have of the tranny before the cases went together
I guess it's possible it could be a shifter drum issue? Maybe?
« Last Edit: September 03, 2013, 04:15:24 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline RSchaefer
« Reply #6 on: September 04, 2013, 08:01:01 AM »
Back in the day I use to pull wheelies and shift between 1st and 2nd with the front tire in the air.  After showing off this way several times I notice I could go through the gears and when I went from 4th to 5th, no 5th, like I was in neutral.  Turns out I stripped the notches in 5th gear.  Apparently the dogs from 4th engage with the 5th gear notches and the same movement occurs when you shift between 1st and 2nd i.e. the 4th to 5th dogs engage.  I had to split the cases and replace, I'm thinking 5th gear.
So hopefully this is not your problem but something tells me you are going to have to split the cases!
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline SKTP
« Reply #7 on: September 27, 2013, 10:33:15 AM »
Found another tranny pic before the cases went together...I doubt it can answer any 5th gear slipping questions, but I thought I'd post regardless...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
