Mrfreeze..In an earlier post I stated that I got a brand new set of airbox to carb boots from ma dealer in Montana that had 1 set on the shelf out back. Clamps are good and tight at the intake and the engine sides of the carbs and I assure you there are no airleaks..I sprayed either to check already and then RPMs didn't change.
I know my way around carbs and all about airleaks and where to check. I have dipped these carbs for a full 24 hrs in Berrymans, new orings all the way around, new vacuum lines from the stall preventer and selinoid..blah blah blah. Still I am stuck with them as I have previously described. The bike shouldn't even be barely running with the screws all the way in....if at all...right??? So what gives here? I try to completely restrict everything that is supposed to meter fuel and get no responses.
Can I go back in history on the bike for a minute? Specifically: was there a period of time when the bike sat, after 1994, for perhaps a couple of years, or more, with the carbs dry? Reason I ask: when these carbs have been exposed to the MTBE we used to have, then they were allowed to dry out after their anodize was eaten away by this stuff, but with MTBE fuel sitting in the carbs, it can (and often has) cause the main air bleed passage between the bellmouth and the emulsifier tube area to generate a fine, white powder inside. This stuff, once re-wetted, sets up like a stiff baking soda and partially (or even fully) blocks the main air bleed hole(s). When this happens, the carbs run rich, the air screws have no effect, and the plugs turn black in less than 100 miles. Sometimes the formaldehyde-based fuel preservers also cause this problem, which is one reason why I recommend they never be used on these bikes.
In recent years, I have repaired several sets of the 657A/B and 7A/087 series carbs that had this problem. The cure is tedious: you have to pull out the emulsifier tube and sometimes the needle jet (be careful, or those can be easily damaged and distorted) and then run a flexible wire back and forth between the bell inlet hole and the emulsifier to scrape this powder loose and out. Then it can be washed out: I use brake cleaner for this, as it seems to help dissolve it a little along the way. It is not easy to remove this "crust", but if just 25% of this bleed is blocked, the emulsifiers cannot get enough air. Even drilling out the emulsifier holes beyond .040" will not help, as the air supply itself is just not there.
