Author Topic: CB750: CycleX MLS Base Gasket.  (Read 3008 times)
« on: September 07, 2013, 06:50:07 PM »
Does one use gasket sealer on the CycleX MLS base gasket? I was going to call them Friday and forgot.
Offline lucky
Re: CB750: CycleX MLS Base Gasket.
« Reply #1 on: September 08, 2013, 04:13:19 PM »
I would use Gaskacinch. Apply it with CARE to each surface then when it is dry slide the gasket on. Originally Honda did not have any sealer on that gasket.
Offline bert96
  • past ride
« Reply #2 on: September 08, 2013, 05:11:12 PM »
 I don't think its recommended to put anything on a MLS gasket.
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline iron_worker
« Reply #3 on: September 09, 2013, 09:13:23 AM »
Ken @ Cycle X told me to install his gaskets DRY. He also emphasized it like that too.  ;D
IW
« Reply #4 on: September 09, 2013, 09:17:49 AM »
NO! It's already coated. It's not a standard gasket like Lucky may think.
« Reply #5 on: September 09, 2013, 09:33:08 AM »
IW
Jim at Cycle X just told me the same thing. Dry it is. Thanks everyone.
Black 750K8
« Reply #6 on: September 09, 2013, 10:08:20 AM »
Lucky How many CycleX MLS base gasket have you put on? Why would you go against Ken @ Cycle X. I have noticed when someone post a complete contradiction to yours you don't post back to explain. Would you care to explain this one? Maybe Ken will learn something.
Offline Pecantree
« Reply #7 on: September 09, 2013, 10:31:51 AM »
Ron:
Curious, are the surfaces milled?
What I've been reading emphasizes PERFECTLY flat and with a smoother finish than normal.
I do not have any experience with them yet.
Steve
« Reply #8 on: September 09, 2013, 10:41:17 AM »
Ron:
Steve
Yeah, except the cases themselves. All Mike Rieck's work. Very flat.
lamillertime
« Reply #9 on: September 09, 2013, 02:23:54 PM »
I'm running one on my 750. As others have said it is recommended to install them dry with milled gasket surfaces. Since my surfaces were not milled with a few light scratches I erred on the side of caution and used permatex  copper coat. Ive had no issues in ~4000 miles, but I am not certain it was necessary, and I do not know what the results of installing one dry on non milled surfaces would be. To me gasgacinch would not be a suitable sealant for an mls gasket, if one were to decide a sealant was necessary.
« Reply #10 on: September 09, 2013, 05:06:35 PM »
I have used 1104 (1194 now or Hondabond, Yamabond etc)on steel/viton coated base gaskets secondary to questionable surface finish and flatness. I had to do it on my FJ on the right side as the oil feed is there and I had  bad experience on a previous build. No leaking now. The key is to use a very small amount.
« Reply #11 on: September 09, 2013, 05:28:56 PM »
OK. I will use Gasgacinch (= HondaBond IIRC) per this post and PM. Around the oil passages, lightly. Maybe apply with a Q Tip.
