Author Topic: 72 cb750 Project,GSXR front end- Version 2.0 coming  (Read 59563 times)
Offline Finnigan
Re: 72 cb750 Project,GSXR Front end--Engine rebuild almost done
« Reply #125 on: December 03, 2013, 01:01:41 PM »
Strong work!  Doing the front end on my cb750F as well.  Your bike looks tough :)
Offline jojo
Re: 72 cb750 Project,GSXR Front end--Electrical Gremlins, please help!
« Reply #126 on: December 16, 2013, 01:14:17 PM »
I have a couple of questions regarding my wiring and how everything should be installed. I am using the controls that came with the gsxr front end (left and right hand controls) and am having some issues wiring them up. Here are my questions, hopefully someone can chime in and help me out.
bike is a 72 750k
1. the starter solenoid has 3 cables on the positive side (1 for battery terminal, 1 red and yellow with bullet style connector, a short, red, cable that i have no idea what it goes too). Does anyone have any idea where this needs to be connected too?
2.There is a short greenish color wire (non bullet style connector) that comes from the harness by itself and i cant figured out if its just an aux cable. It does have current when checked with the test light.
3. my manual only shows 1 fuse but my box has 3 of them installed and only the lowest one has power going to it. Any idea what the top 2 are for or what would cause them to not have current going through them?
Thanks for the help!
Jay Ace
« Reply #127 on: December 16, 2013, 01:17:41 PM »
Mine didn't come with the stock fuse box so I am not positive but I think the other two slots are for spares ...
Offline jojo
« Reply #128 on: December 16, 2013, 01:36:41 PM »
well, im not sure because the top 2 are different amp levels and the fuse box cover has spares on it so im guessing they do go to something.
I will upload some pics as soon as i have a chance.
Offline jojo
« Reply #129 on: December 16, 2013, 02:13:40 PM »
i pointed at them with the arrows
the first cable is a light greenish color, it looks like a part of the dark green ground cable thats bolted to the frame but its not.
on the red one, dont mind the black cable connected to it. i was using it a power source to test my tail light.
Those are the two bad boys in question.
Offline danfr
    • Apollo Motorcycles
« Reply #130 on: December 16, 2013, 03:11:12 PM »
Not too sure if this is much help, but red wires are typically a (+) power wire that runs from the battery before the key ignition. Power supplied from the key ignition and onwards are typically black. So you rectifier, fuse and your solenoid could have red wires running to the battery.
Light green eh? Is it paired with another wire? If it was towards the front of the harness I would guess horn, near the rear, possibly rear brake switch. Look around at the electronics where the light green wire is placed on the harness. And deduct what it could hook up with.
Are you sure you have the right harness?
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline jojo
« Reply #131 on: December 16, 2013, 05:00:55 PM »
that greenish  wire isnt the one for the horn. I was able to get the horn working and that wire didnt have anything to do with it.  mmanaged to get the horn to work today.
the harness should be the correct one since it was the one that came with the bike.
Online HondaMan
« Reply #132 on: December 16, 2013, 06:02:55 PM »
The Yellow wire (probably has a Red stripe on it, too) is the +12 volts from the START button. The Greenish wire (should also have a faded Red stripe) is the ground side of that solenoid. So, ground the Green one, and apply +12v to the Yellow one to make it engage.
The 2 big terminals get connected together when the solenoid is ON. They are not polarity-sensitive: either one goes to the engine starter, the other to the battery (+) terminal.
Offline jojo
« Reply #133 on: December 18, 2013, 02:12:08 PM »
Hondaman- I was missing a ground so i secured it to the frame to make sure. I finally figured out what was wrong. Turns out someone had previously messed with and spliced the original suzuki controls. everytime i was hitting the starter button it was causing it to short out.  a few curse words, some splicing and dicing of the controls and now it all works!!!!!!! thanks again everyone for your help.
Offline jojo
« Reply #134 on: December 18, 2013, 02:21:00 PM »
 the culprit
Offline jojo
« Reply #135 on: December 18, 2013, 02:32:58 PM »
almost done. Few things let to do. Finish fabricating/mounting the taillight brace, rear set linkages, front fender, sort out how im going to mount the headlight, new steering stops, and spacers for calipers. Sounds like a lot but im almost there!
also taking a poll..wich tail light do you prefer? Both of them have integrated turn signals. trying to keep the rear as sleek as possible.
or
Offline edwardmorris
  • Youngish
« Reply #136 on: December 18, 2013, 02:58:53 PM »
Second/Square/Big one. Safety first, you want that thing to be seen from a good distance.
Offline jojo
« Reply #137 on: December 19, 2013, 07:32:53 AM »
If it's LED, oval unit. My LED will burn a hole in the windscreen from 100 yds at night. I pity the car behind me...
They are both LED units. I just think the oval one fits a lot better with the look of the seat and gives me more space to work with since the bike is sitting pretty low. The square one is off a ducati monster with the sequential turn signals which is the main reason i bought it but seeing as i dont have much space i may be out of luck.
Offline jojo
Re: 72 cb750 Project,GSXR Front end--no spark issues...
« Reply #138 on: January 04, 2014, 11:26:28 PM »
Have some updates. Finally moved out of the rented shop space i was working out of and now working from home. The bike was running before the move but now im not getting any sparks to the wires. I already checked the coils and the cables are all connected. Also checked my grounds and all are connected properly.
Would bad points cause me to have no spark? What else do I need to check?
Offline jojo
« Reply #139 on: January 05, 2014, 04:10:40 PM »
Got it sorted out, the black/white cable coming out of coils were connected incorrectly and werent getting current. Now I need to do the timing since cylinders 1and 2 are firing correctly
Offline jojo
Re: 72 cb750 Project,GSXR Front end--almost there!
« Reply #140 on: February 11, 2014, 03:31:41 PM »
  Finally got around to wiring my acewell
mounted it on the top triple, drilled and tapped it and IT WORKS!
Then my dad (anti motorcycles)  came to visit this weekend and he hoped on for a pic after we got it running. spark plugs 1 and 2 were soaked and had gone bad after some wiring issues caused them not to get sparks.
Then while watching that 70's show found this bad boy!
Couple of questions for yall.
1.) cb550 swing arm is a bit longer than the 750 so my chain is now too short. What is the better solution, new chain(current chain isnt but a few months old) or smaller rear sprocket?
2. anyone make brake lines? the current line for my second caliper is too short (old wheel was smaller, 17 inch vs 19 inch) and now it rubs against the wheel.
3.) carbs seem to be sticking, not sure if its the cable or a bad return spring will be loading a video soon.
Thanks again everyone for your help, im almost there.  :o 8) ;D
« Reply #141 on: February 11, 2014, 06:03:01 PM »
Slingshot here on the forum makes brake lines.  If you need custom lines outside of what he makes, you can order them custom from Motion Pro.
Offline heyitsrama
« Reply #142 on: February 11, 2014, 09:20:37 PM »
I was adjusting my throttle cables last night to try to get the carb stick to go away. I ended up just adjusting the bolts that hold the
black wire|bolt][Screw][bolt][ on the top of the carbs and got it to snap back into place.
thats a really bad explanation....
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Offline WhyNot2
  • I'm finally an
« Reply #143 on: February 12, 2014, 03:34:08 AM »
Kewl build.
Offline jojo
« Reply #144 on: February 12, 2014, 07:18:15 AM »
thanks!  i understood you
Offline jojo
« Reply #145 on: February 12, 2014, 07:25:17 AM »
Thank you sir, i will get a hold of him here pretty soon once i get my forks back together. Busted a fork seal when we were moving it so im going to replace them both and get it over with
Offline WhyNot2
  • I'm finally an
« Reply #146 on: February 12, 2014, 01:54:43 PM »
OK......seat questions...............where did you get it?
Is it a direct bolt (pin) on?
And can you go into more detail why and what did you do to reinforce it?
Thanks
Jack
Also.....how much longer is the 550 swingarm......that is something I'm wanting to do to me 750?
« Last Edit: February 12, 2014, 02:27:14 PM by budlite282 »
Offline jojo
« Reply #147 on: February 12, 2014, 02:38:24 PM »
Thanks
Jack
Jack- seat is from dime city. its not a direct bolt on. the front part of it is a bit narrow for the 750 frame but barely noticeable. I ended up making a aluminum pan i fastened to the seat using threaded pop rivets. Then i inserted some studs using loctite to lock them in and fastened them using wing nuts and rubber spacers to dampen it a bit. Ill take some pics to show how i did it .
the swingarm is about an inch and a half longer than the 750 one so you will need a longer chain.
« Last Edit: February 12, 2014, 02:44:57 PM by jojo »
Offline snowman
« Reply #148 on: February 12, 2014, 03:16:19 PM »
Nice build, I'm subscribed.
Sent from my iPad using Tapatalk
Offline WhyNot2
  • I'm finally an
« Reply #149 on: February 12, 2014, 03:19:53 PM »
Thanks
Jack
Kewl....thanks jojo.....quick response....chain is not an issue for me I hope.
Mine also is relatively new. So we'll see.
That from end swap is what I really want to do.....but, at the time, 550 front forks and a 550 swing arm is gonna give me the look I want on my 750 for the time being.
Thanks my man
Jack
