It took me a long time, but finally 4 hours in the local salvage yard netted the result. I put an 18" front wheel on my CB750 and wanted the stock look to the front fender. It is a CB350F front fender. You'd never know it from stock 19", except that its 18. Fender stays and the works. Cost me $5 each.
YEs I got 2 of them. One was bobbed in the front, which I am using. The other is full circle. But I'm afraid I can't let it go.
But you have your answer. IT wasn't a direct bolt up. The stays work fine. But the center saddle bracket has to be removed and yours fitted in its place. In my case, the center bracket is my fork brace and I bolted the fender to that.
