I read a little about this a while back but can't seem to find the threads using search today.
I know you have to drill out the 550 frame for the larger 650 swing arm bolt.
I have some 550 axles, so I can check this myself later, but does anyone know if the 550 axle fits the 650 swing arm?
What about the brake rod stay? I have a couple of 550 stays....were the 650 stays longer?
Lastly, I assume you use the 550 brake pivot and rod? Will it be long enough?
