Author Topic: 1972 CB750 Four K2 -- Rebuilt to NEW OLD STOCK -- PIX ON PAGE 50  (Read 299068 times)
Re: 1972 CB750 Four K2 -- Project "Ice Cream"-- HOME STRETCH
« Reply #1150 on: June 19, 2015, 01:58:35 PM »
Slight resistance is the goal, good feel comes with experiemce. A pop is sometimes from a too tight ex valve. Too loose is better for start up, reset is always good. Check #4 to eliminate the variable. It should "click" at touch.
If it is too tight, and you run it, you'll burn it.
« Last Edit: June 19, 2015, 02:00:24 PM by MCRider »
Offline Desert-SOHC
  • It's old
« Reply #1151 on: June 19, 2015, 02:07:41 PM »
Very nice bike
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline edwardmorris
  • Youngish
« Reply #1152 on: June 19, 2015, 08:40:31 PM »
Yikes! I'll check it first thing tomorrow. Was going through the manual and this IS the first thing to check, followed by ignition timing and insufficient fuel. That last one is a possibility as I had to readjust the floats after #4 started overflowing. Thanks a bunch Ron!
« Reply #1153 on: June 20, 2015, 08:57:50 AM »
Did you replace your tappet adjusters, or inspect them for wear? They wear with a channel in them where they push on the valve tip. When you adjust them, turn the adjuster, that channel get s repositioned and if bad enough will give false readings. OFten the tip is flat out pitted and must be discarded.
Pull your #4 and take a look.
I got 30 adjusters from a salvage yard one time. Fully 1/3 of them were worn past using, 3-4 had deep pits. New ones were cheap enough I just bot them, OEM.
Offline oldhatt45
« Reply #1154 on: June 20, 2015, 05:15:12 PM »
Ed,
The rest of the Guys have said it all!
Really Nicely done and for sure a BOTM and BOTY candidate!!!!!!
Have fun and be safe riding her
Charlie
  • Youngish
« Reply #1155 on: June 20, 2015, 06:20:56 PM »
All NEW/NOS tappets and nuts.
Checked the gap, its still nice with slight resistance.
Checked the floats, all looks good, plenty gas coming when turned on.
Checked the plug gap, good also, but did notice some carbon deposit on the electrode. I'm guessing its from the initial startup when the idle was at 4000 RPM. Doesn't seem to have gotten worse after today's short run.
I'm guessing this has to do with the idle mixture now? Pop hasn't gone away, and after talking to Jerry, I AM noticing it happen when decelerating as well, not just at idle. This is getting annoying, want it to get smooth enough for a good dynamic timing, then install the Hondaman ignition.
Checking the idle screws next, good idea or is there something else I should look into?  Thanks for the help with this Ron.
@Charlie, thanks!
  • Youngish
« Reply #1156 on: June 21, 2015, 03:46:23 PM »
The pop is almost gone, down to very very little at low idle. Mark/Hondaman suggested that #4 carb slide height wasn't quite right, increased it slightly and it got better, will increase it some more to fully get rid of it.
Installed the NOS mirrors, bleeder screw cap and tank trim. Logged 4 more miles, nearing 10! I'm just way too tired to do any more right now  :(
Does anyone know where this sticker goes on the K2? This thread says "headstock", but where is that?
http://www.sohc.co.uk/index.php?topic=3255.0
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #1157 on: June 22, 2015, 05:26:50 AM »
Headstock = steering head on frame.
In terms of location, through, I have no idea. the VIN plate goes on the Left though, correct?
--Evan
1975 CB750K "Rhonda"
  • Youngish
« Reply #1158 on: June 23, 2015, 09:35:53 PM »
Installed the NOS points cover with screws today, my friend came over to do the photo shoot, had to shine things up. Installed the Franken Finserts, pretty tight fit, gotta line a couple of them up still.
  • Youngish
« Reply #1159 on: June 23, 2015, 09:41:05 PM »
Installed the fork lock with a new cap from yamiya and a stainless screw. Still need to figure out where all the warning stickers go. Got the tire pressure, Engine Oil and Preserver Nature and the Exhaust ones in place. The battery caution sticker didn't start until the K3, so may skip that along with the headstock one. Early K2s didn't come with those IINM.
Getting killed when it comes to finding the time and strength to log more miles, but I did get 7 more on it today after the photo shoot. I need to get the dynamic timing and carb sync done soon. There is still a pesky drip at one of the carb drain screws. Does anyone know if the 7A drain screws use a aluminum crush gasket or a rubber one? The rubbers ones aren't working all that well from what I see.
Offline Tews19
  • I am no
« Reply #1160 on: June 24, 2015, 07:07:35 AM »
Rafi, Not sure if you want to answer this question but what is the total cost of the build? You need to post a complete before and after pic too bud!
1970 Honda CB750 survivor.
  • Youngish
« Reply #1161 on: June 24, 2015, 10:01:59 AM »
I am by no means an expert on those bikes, but I would find it difficult to believe the drain screws would use ally crush washers as the torque needed should surpass the thread strength. My opinion, and I have been wrong before about these idiosyncrasies.
I thought so too, but this one isn't letting up. Might just be a bad gasket, will swap it out and see. When I tighten the screw, the gasket managed to spread and slip over the screw head and fall off at one point  :o I only asked about the crush washers because the kit came with both the rubber ones and the aluminum ones (not talking about the sync screws alu gaskets).
  • Youngish
« Reply #1162 on: June 24, 2015, 10:07:33 AM »
Its quite high, needless to say those NOS HM341s are the biggest expense (cost, foreign transaction fee and international shipping). I'm afraid its not going to sell   :( I will need to sell it, I can't drive my car that I purchased used in college forever, its already pushing 220K  :o Need me a work horse to get to work :-\
I'm working on the final batch of pix, haven't received any from the shoot yet, hopefully soon. I don't have  a lot of the before pix, but there are a couple that should work. Last item (I know, no such thing) is to figure out how to properly roll up the NOS toolkit I have for it. Also thinking about going with an authorized reprint of the owners manual, original are too pricey for their shabby condition ::).
« Reply #1163 on: June 24, 2015, 10:36:03 AM »
MAN!  The sheer number of HONDA GENUINE PARTS bags in this build string is staggering. This is like a Vic World CB750K0 build with all NOS parts.  I cannot imagine the parts cost, but I still love it!
Offline Tews19
  • I am no
« Reply #1164 on: June 24, 2015, 01:13:31 PM »
So you are going to sell the bike? I am not sure if I am understanding?
  • Youngish
« Reply #1165 on: June 24, 2015, 01:23:13 PM »
I'm going to have to, yes. Not thrilled about it, but I've kinda put a lot of stuff on hold to get this one done, like my car, and more critically, I need a new roof :o Not going to be easy parting with it, but its not going be an easy sell either ;)
« Reply #1166 on: June 24, 2015, 07:33:13 PM »
Curious, what do you think the asking price is going to be?
Sadly, not high enough to cover all those receipts.
« Reply #1167 on: June 24, 2015, 08:34:57 PM »
I think with any meticulous (concourse style) restoration or highly-customized build, it is impossible to recoup all of the building costs. It's really is a shame you cannot hold on to the bike.
  • Youngish
« Reply #1168 on: June 25, 2015, 10:27:12 AM »
Absolutely. And worry not, it looks like I'm stuck with this thing. I started running the numbers and stopped after it crossed 20K to save myself a cardiac event. Already depressed, feeling so irresponsible, and feeling bad for my dear dear patient wife. There is very little chance this will sell. I've seen overbuilt customs sell for less, and barely restored blandcasts sell for more, so there is a glimmer of hope for this one. Maybe a rich collector who understands that the early K2s (11/71 and earlier) are fewer in number than the sandcasts will grab it (I know, wishful thinking). This will simply have to become my long term investment for now, and the K3 build will be delayed.
I'd rather not post the breakdown, but I'll share it with prospective buyers if any.
Back to finishing this thing up, can someone who still has a tool kit for these please post a pic of how it rolls up and stays in the tool tray?
« Reply #1169 on: June 25, 2015, 12:42:19 PM »
Rafi: Never heard of a roll up toolkit. Mine is K2, original, and its a vinyl bag the tools drop into loosely. I'm pretty sure all Ks are that way. Fits in tray easily.
PS: My K1 was that way too.
« Reply #1170 on: June 25, 2015, 02:40:38 PM »
My K2 tool kit was that way, too, before someone pilfered it!
  • Youngish
« Reply #1171 on: June 25, 2015, 04:27:59 PM »
Thanks for that, I described it poorly. I do have the right one, I wasn't sure that it would clear the seat when down, but it worked out perfectly!
I tried pulling the battery strap over but its a bit too short, will order the slightly longer version along with the reprint of the user's manual later.
  • Youngish
« Reply #1172 on: June 25, 2015, 05:03:16 PM »
And here are some before and after shots.
Detailed glam shots later, I'm tired of uploading right now ::)
« Last Edit: July 20, 2017, 01:59:03 PM by edwardmorris »
  • Youngish
« Reply #1173 on: June 25, 2015, 05:08:42 PM »
PLEASE refrain from "quoting" the above post to keep the page view manageable, thanks!
« Reply #1174 on: June 25, 2015, 05:12:17 PM »
It is amazing to see one of these K2's roll off the production line again.
