Author Topic: CB 750 Project 1 - Rides Well but a few tweaks needed  (Read 114943 times)
Re: CB 750 Project 1 - Getting the Carbies installed
« Reply #625 on: September 05, 2016, 05:06:43 PM »
G'Day Tim, there should be (or at least, was once) a metal tab at the back of your engine with a slot to poke all the overflow tubes, but if you don't have it any more, as long as they're all bunched together between the back of the engine and the swing arm, it'll be fine. Cheers, Terry. ;D
Offline timbo750
« Reply #626 on: September 05, 2016, 05:51:11 PM »
Terry, is that a 12mm hole through the case? I think I but a bolt through it if it is.
Sent from my SM-G920I using Tapatalk
« Reply #627 on: September 05, 2016, 06:24:49 PM »
G'Day Tim, no the little metal plate with a long slot pressed into it has an 8mm hole and mounts on the bolt to the right of that 12mm hole. Cheers, Terry. ;D
Offline timbo750
« Reply #628 on: September 05, 2016, 10:00:50 PM »
Terry I don't think I have seen anything looking like that. I will sort out something that will do the same.
« Reply #629 on: September 05, 2016, 10:57:04 PM »
Yeah, it's probably been lost over the last 40-odd years mate, a cable tie will work just as well. P.s, I think I bum-drummed you, it only has a 6mm hole and is located on the vertical crankcase through-bolt behind the kick starter. Cheers, Terry. ;D
Offline timbo750
« Reply #630 on: September 07, 2016, 06:12:03 PM »
A few more photos for anyone interested, when I first cleaned and rebuilt the carbie I was very happy with how they looked as they were in a very bad shape when I got them but now compared to the freshly painted engine they don't look so clean.
Offline timbo750
« Reply #631 on: September 07, 2016, 06:25:18 PM »
The next question I have to brains trust out there is about the airbox and no I am not going to put pods on (this bike anyway).
I have two lower sections that are very different and would like to know which one would be better.
« Reply #632 on: September 07, 2016, 09:55:05 PM »
Use the correct one Tim (the one with the butterfly head screws) if you try to use the "F" air box you'll crack your sidecovers, as the F air box (the other one in your pics) is slightly wider. Cheers, Terry. ;D
Offline timbo750
« Reply #633 on: September 07, 2016, 10:10:24 PM »
Thanks Terry
« Reply #634 on: September 07, 2016, 11:06:15 PM »
No worries, but on reflection, it's the F2 air box that's wider Tim, so you'd only have a problem if you installed F2 carbs. I'd still use the K series air box on your bike though. ;D
Offline timbo750
Re: CB 750 Project 1 - Back to Getting the Wiring Installed
« Reply #635 on: September 10, 2016, 08:15:35 PM »
Working on getting the wiring all hooked up now but I also need to get the fuel line out of the way in the right position. With most things still not in place there are few places to run but I know there is only one that will avoid entanglement and issues. The first 2 photos show where i have it sitting now and I am sure it is wrong, the third show an area where I think seems to be best, can someone confirm please and if I am wrong please send me in the right direction.
Offline maduncle
  • Don't confuse me with a
« Reply #636 on: September 11, 2016, 03:27:05 AM »
Well - first I would cable tie that wiring harness down tight along the frame and out of the way.
Then route your fuel lines back to the petcock.
CB750K2 (only slightly modified)
Offline timbo750
« Reply #637 on: September 11, 2016, 01:47:11 PM »
Cliff, yes the wiring needs cable ties and needs a few more connectors made up to for the coils. I am just being a bit OC on where some of these things finally sit and just want to get the fuel line out of the way as it is giving me the #$%*s.
« Reply #638 on: September 12, 2016, 02:10:07 AM »
You're right Tim, they're not routed correctly. Take a look at the cast backing plate between carbs #3 and 4 and you'll see two holes. the hose from #1 and 2 goes thru the bottom hole, and #3 and 4 thru the top hole. Have fun finding somewhere to install inline filters! (you should) ;D
Offline timbo750
« Reply #639 on: September 12, 2016, 02:59:52 PM »
Thanks Terry. Picked up a new tee b piece for the fuel line as well so will sort that soon.
Offline timbo750
« Reply #640 on: September 12, 2016, 11:24:09 PM »
On a different note, I picked up some parts today and I also now have seen one of those little tabs you talked about Terry. I didn't need any of it now but I have 3 frames and now nearly have 3 complete engines, what's more it has an alternator cover in very good condition.
« Reply #641 on: September 13, 2016, 03:38:25 AM »
Well done Tim, and if you want to sell any or all of those unwanted parts, let me know, cash waiting! Cheers, Terry. ;D
Offline timbo750
« Reply #642 on: September 13, 2016, 04:25:40 AM »
Terry . Just let me know if you need anything. Still have that K0 front hub.
« Reply #643 on: September 13, 2016, 04:44:30 AM »
Thanks Tim, I still need the hub for my K0 resto, and I like to stockpile whatever parts I can get my hands on for future projects. I'm thinking about putting up another shed when the weather improves so I can park my bikes in one, and my parts in the other. At the moment, my garage is more like an obstacle course......... ;D
Offline timbo750
« Reply #644 on: September 13, 2016, 01:27:53 PM »
Terry, that would give me shed envy, I have a small shed at home where I work on the bike and no a lot of spare space. But I do have an old storage room room at work that about the same size as my shed for keeping all the extra bits I have. I too like to have heaps of extra bits and pieces, I plan on working on bikes for as long as I am standing, gets me out of the house and stops me thinking about work.
Offline maduncle
« Reply #645 on: September 15, 2016, 05:18:55 AM »
How the hell did you find CB750 parts for sale in Victoria before Terry?
Shepparton swap meet?
Anyway - nice score Tim, looking forward to going for a ride with you once you bike is built.
S'pose we should invite Terry too ...
Offline timbo750
« Reply #646 on: September 15, 2016, 12:06:30 PM »
Got them off FB and they were listed for 2 weeks before I picked them up.
Yes Terry can join us on a ride.
Offline timbo750
Re: CB 750 Project 1 - Next Issue
« Reply #647 on: September 16, 2016, 11:26:08 PM »
I thought I was at a point where I had all the parts and had the right parts, but wrong again, the learning continues.
Turns out the airbox I thought was the right one after some feedback from Terry can't be the right one, this is unless the engine is somehow in the wrong spot. I was fitting up the top half of the airbox to make sure that when i cable tie the harness that they aren't trying to occupy the same space but the airbox does not match up to the carbies.
But I did manage to get something done, the rear brake switch is now attached.
« Reply #648 on: September 16, 2016, 11:52:32 PM »
Well done Tim, that is the correct airbox, you just need to rotate your carb to head rubbers (Are they genuine Honda ones?) to lower the angle of the carbs. I think I better come along for a ride with you and Cliff, you two need someone who knows CB750's........... ;D
Offline timbo750
« Reply #649 on: September 17, 2016, 12:09:23 AM »
Terry,  you are the master and I would not be this far yet without the valuable advice.
I bet rotating those rubbers is easier said than done , I am imagining that I need to remove the carbies again.
