My cb650 would rev up fine in neutral, but under load would hit 6-7K and not go any farther. Ive adjusted all the timing,advance,valve,pulse gap,carb ( carbs ARE clean) ect. Here is what i find weird, i take the air filter out, run the airbox cover and side cover, but no filter, and i can rev to 10K, and loads of power. Which tells me the bike is rich. However the bike has a Mac 4-1 exhaust and stock 120 jets, wouldnt the pipe lean the bike out? It just seems weird to me that the bike is running so rich with the stock jets! BTW this is an 81, so not a lot of adjustments on the carbs. Any ideas?
