« Reply #51 on: September 23, 2013, 04:19:52 PM »
Octane rating and burn rate are two different variables. There are high octane fuels that burn faster than 87 pump gas, and there are high octane fuels that burn slower than 87 pump gas. It is the same thing as saying that people who can lift heavy objects run slower than people who can't lift heavy objects. There are plenty of people who can out lift and out run me ![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
Burning up exhaust valves has to do more with the temperature of combustion rather than the length of combustion. Some fuels (especially ones with higher oxygen levels) will burn leaner than others. If the jetting is not adjusted then you will end up with a hotter combustion that will cause problems in the long run. In general you will not see anything like this simply going from 87 pump gas to 93 pump gas though, you would need to jump to a much more exotic fuel.
I was under the impression the entire reason for octane rating was to maintain anti-knock and burn rate? (since 1915~1916?)
My first reply (post #3) says to adjust jetting as E10 fuel leans mix
Burn rate and ignition susceptibility are two different properties. FYI
![](http://forums.sohc4.net/Themes/default/images/ip.gif)
Logged
