Author Topic: Brake Light problem  (Read 840 times)
Offline Lost and Confused
  • Bob
  • An old fart !!
Brake Light problem
« on: September 21, 2013, 11:47:22 AM »
1974 cb750k. All lights work except rear or front brake light. I've checked power and fuse. I'm curious if the sending unit that's located on the triple tree, is bad. I know that the wires coming to the rear brake switch are black and green/yellow, the wires going to the hydraulic   switch on the triple tree are black and green/yellow. This is why it failed inspection last week.
Bob
Offline Vinhead1957
Re: Brake Light problem
« Reply #1 on: September 21, 2013, 03:33:29 PM »
Or check the continuity between the connections. When active they are shorted.   If you don't have either brake most likely power from fuse check there first.
