Author Topic: Fitting Dyna Coils  (Read 1505 times)
supersport_CB400F
Fitting Dyna Coils
« on: August 16, 2006, 10:40:21 AM »
The Dyna laminated core of the coil is about 2.7 mm wider than the stock coil to frame hanger brackets, anybody else had this problem? If you did you take the excess off the core or the bracket or just make a new hanger?....Cheers
« Last Edit: August 16, 2006, 10:42:33 AM by _biffta_ »
Offline Bodi
Re: Fitting Dyna Coils
« Reply #1 on: August 16, 2006, 10:50:28 AM »
I just took a file to the stock hangers. I do have a spare set, but I think if you ever wanted to use stock coils again the modified hangers would still work OK.
supersport_CB400F
« Reply #2 on: August 16, 2006, 10:56:23 AM »
Theres not much metal in those hangers, I'm having one or the othe part milled, I just wondered which was best to have the excess removed from.....Cheers
eldar
« Reply #3 on: August 16, 2006, 01:53:28 PM »
The cores on the coils are generally made a certain way for a reason. You start grinding that and it could alter the operation of the coil in some way. I would just make or modify the bracket.
supersport_CB400F
« Reply #4 on: August 16, 2006, 02:24:51 PM »
I heard the laminations are insulated, but wasn’t sure if machining them would be a problem as they sit in a metal hanger that touches the sides, bottom, end and also have a bolt going through all the plates…….I put a meter on the top plate and bottom plate of the old coils and got continuity with no bolt just the coil core, I’ll measure the Dyna’s in the morning they’re in work…… but it’s looking good for work on the hanger just now even if they will be flimsy…. cheers
