Author Topic: How do I align the front sprocket to the rear?  (Read 5107 times)
Offline Mista750
« on: September 22, 2013, 02:07:11 PM »
I bought a 76 CB750F and the PO swapped out the motor from a 78 K. I finally got the bike running and noticed that no matter how I much I tried to align the rear wheel, I couldn't get my chain to quiet down. So removed the chain to check for alignment and found that the front sprocket is about a sprocket width off to the left. Any advise on how to fix this?
« Last Edit: September 22, 2013, 02:16:10 PM by Mista750 »
Offline bert96
  • past ride
Re: How do I align the front sprocket to the rear?
« Reply #1 on: September 22, 2013, 03:02:32 PM »
Maybe an off set sprocket from Cyclex.
http://www.cyclexchange.net/Chain%20Sprocket%20Page.htm
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #2 on: September 22, 2013, 03:08:35 PM »
I have a '77F, not a K.
Your pic shows what looks to be a nut between the sprocket and seal. According to my parts list it shouldn't be there on an F. Might be the problem with yours?
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline 750K
« Reply #3 on: September 22, 2013, 04:17:42 PM »
Easiest way around it is the 10mm offset rear sprocket, 77-78k's have the front counter shaft and rear sprocket carrier 10mm further outboard as well as a wider swing arm and left rear shock mount on the frame. So getting an offset sprocket is most likely easier unless you have a complete 77-78 rear end setup to scavenge parts off of.
77 Cb750, 78 Kz1000
Offline Mista750
« Reply #4 on: September 22, 2013, 04:29:32 PM »
Awesome! That will work! Thanks Bert!
Bert
Offline Bailgang
  • Scott
  • Indiana
« Reply #5 on: September 22, 2013, 04:55:13 PM »
It takes just a bit more than a complete rear end set up from a 77/78 because the top left side shock mount on a 77/78 frame sticks out 10mm farther out as well. I put a 77k engine in my kid's 73k frame and I had all the 77/78 suspension hardware, sprocket hub and spacers to do it but that left shock mount stalled us. Not a big deal to fix except the frame was 2 1/2 hours away from here where my welder is. The bike needed new sprockets anyhow so my kid left the 73 rear end setup intact, got the rear offset sprocket from cycleX and all is well.
« Last Edit: September 22, 2013, 05:01:11 PM by Bailgang »
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #6 on: September 22, 2013, 05:21:37 PM »
It takes less than that , 4 machined spacers or. 1 big one for the rear sprocket..may need longer studs..
Or use the 77/78. Rear carrier. ( and inner spacer). That will solve sprocket problem.
Now you may have to fiddle with axle spacers and shock clearance.
A 77/78 swingarm and axle off correct model. Will help too but is an inch or a bit more longer..needs longer chain
Offline Bailgang
  • Scott
  • Indiana
« Reply #7 on: September 22, 2013, 06:00:55 PM »
And that was what the issue was with ours. We would've either had to mess with spacers if using the 77 carrier in the 73 swingarm or mess with the top left shock mount when using the 77/78 swingarm and carrier. Not a big deal actually except frame was there and equipment to do it was here. With the cycleX offset rear sprocket mounted on the 73 carrier we weren't able to use the chain guard and the chain does clear the shock ..... but not by much.
Scott
71 cb350 twin
77 cb750 F2
Offline lucky
« Reply #8 on: September 22, 2013, 06:27:42 PM »
The PO screwed you. Sloppy and dangerous workmanship.
IF it has that old #630 chain I would get rid of that and use #530 sprockets and chain.
You will still need that special sprocket from cycle -X for the front countershaft.
« Last Edit: September 22, 2013, 06:29:31 PM by lucky »
Offline Bailgang
  • Scott
  • Indiana
« Reply #9 on: September 22, 2013, 06:51:38 PM »
That's actually a good point because I think the cycleX offset rear sprocket was only available for a 530 chain.
Scott
71 cb350 twin
77 cb750 F2
Offline Mista750
« Reply #10 on: September 22, 2013, 07:09:34 PM »
When i bought the bike, fortunately the PO included the original 76F motor but don't know the condition. I will be looking into rebuilding it and hopefully using it again. But for now, I'll have to stick with the 78K motor.
The chain currently on the bike is a 630. So I looks like I'll be picking up a 530 chain, front sprocket and 10mm rear offset sprocket.
« Last Edit: September 22, 2013, 08:45:56 PM by Mista750 »
« Reply #11 on: September 22, 2013, 07:51:19 PM »
Offset front wont helpunless you can run it negative offset.
 Like I said cheapest way is spacers.. If you were here. A lot of days I would bang them off for like 15-25 bux for the four..
 Most guys with a jig saw diegrinder and drill, should be able to carve a one piece one out of 3/8 alloy plate..n an hour or hour and a half..
« Last Edit: September 22, 2013, 07:54:21 PM by 754 »
Offline Mista750
« Reply #12 on: September 22, 2013, 08:29:23 PM »
Not a front offset but a 10mm rear offset should do it for me. Don't you think? I measured that sprocket plate and it's about 10mm thick.
« Last Edit: September 22, 2013, 08:54:28 PM by Mista750 »
« Reply #13 on: September 22, 2013, 09:44:01 PM »
Yes i know,i dont know why anyone brought up the fronts.
 3/8 = .375    10mm = .394
.   Close enough..
« Last Edit: September 22, 2013, 11:44:26 PM by 754 »
« Reply #14 on: September 22, 2013, 09:54:11 PM »
Lucky, how many times do we have to remind you that the 630 chain was introduced in 1977, and the early chain failures resulting in case damage were with 530 chain? ::)
Offline lucky
« Reply #15 on: September 22, 2013, 11:28:27 PM »
The 1978 engine I got had a hole in the engine case and it had the 630 chain.
And the 1978 models had the thicker engine case in the area around that countershaft sprocket.
BTW I do not like that big fat heavy ugly chain.
IT is the WEIGHT I just do not like. Do I have to keep reminding you all? LOL..lol
Cycle-X uses #520 chain on their powerful road racing motorcycle.
