Author Topic: Turn Signal Wiring  (Read 511 times)
Offline Dirty Steve
Turn Signal Wiring
« on: September 23, 2013, 02:50:19 AM »
Hi all, I've been hunting around the archives trying to figure out how to wire my two-wire front turn signals to the three-wire set up on my '75 CB750. Both wires coming out of the turn signals are black. It sounds like I can connect one to the solid orange (left side)/solid light blue (right side) and connect the other one to ground. Is that right?  Also, is the light blue wire with the white stripe and the orange wire with the white stripe for the running lights?
Thanks.
Riding motorcycles will make you a poet. Working on them will make you a philosopher.
1975 CB750K5 with stock airbox, exhaust et al...
Offline Vinhead1957
Re: Turn Signal Wiring
« Reply #1 on: September 23, 2013, 04:39:21 AM »
Rear signals only have directional. Other than that, you are correct
