Author Topic: 1976 CB500/550 Project "Squirrel"  (Read 346028 times)
Offline riverfever
Re: 1976 CB500/550 Project
« Reply #1200 on: December 27, 2016, 08:03:31 AM »
Hmmmm. Big pasture area or lots of trees around (pines)? If pasture then my guess would be the Dream Stream section out by Hartsel. Not far from my house.
« Reply #1201 on: December 27, 2016, 08:04:19 AM »
In a valley if I remember correctly. I block some of those memories intentionally.
« Last Edit: December 27, 2016, 08:05:51 AM by CB750 Cafe Racer Fan »
Offline riverfever
« Reply #1202 on: December 28, 2016, 02:44:50 PM »
Well this breaks my heart. Seems as if a Colorado trip might be in order for you and your gal. We can fish if you like. Mmmmmmmm......fish.
Offline riverfever
« Reply #1203 on: December 28, 2016, 07:45:28 PM »
I would like to cross drill my rotor this winter. I like the pattern that was used on this bike.
http://www.ebay.com/itm/1976-Honda-CB-/302178076479?forcerrptr=true&hash=item465b37873f:g:oPgAAOSwal5YIRFQ&item=302178076479
I found a template for a CB360 that looks to be the same design. I have some questions.
-Will the 360 template work?
-Any concerns with this pattern?
-If I was to buy a drill press, what would I need in terms of hp to do the job?
Thanks.
« Reply #1204 on: December 29, 2016, 06:37:02 AM »
Maybe it's just me, but I think drilled discs look out of place on vintage bikes.  And don't expect improved braking, you wont feel the difference. And yes, I have had one, "Black Beauty" had one [a very ugly 750 that I sold]
« Reply #1205 on: December 29, 2016, 08:27:12 AM »
Chris,
I have to agree with Cal. That kind of aggressive drilling is more decorative than functional.
Cal's slotted and drilled rotors are on the modern edge.  Check out EBC's simple but functional pattern.  This is farily much consistent with most modern OEM patterns, too.
Offline riverfever
« Reply #1206 on: December 29, 2016, 09:13:38 AM »
Man...I don't believe we have a mill at school but I'll need to check on that. We do, however, have a nice drill press (although I'm not sure of the hp). I'll admit that my motivation for even wanting to do this is because I like the look but I do not want to go overboard. Dono...(;D sorry man I just saw that one and reacted ;D) I like that pattern.
« Reply #1207 on: December 29, 2016, 11:41:42 PM »
Drilling slowly is important when drilling steel, too fast you just burn up / dull the bits even if streaming cutting fluid on the bit.  Carbide drills are the way to go and if it can be slotted as well it will improve wet braking performance.
Offline riverfever
« Reply #1208 on: January 05, 2017, 09:58:09 AM »
I think it was on last Friday that I received a box marked "North Pole Machine Shop" that contained the electrical panel as well as a mount for the M Lock and a few odds and ends. Ironically, (and this really isn't a joke) almost immediately after getting it, I got very sick with flu-like symptoms. Incredible chills, 102 fever and aches and pains. The next 36 hours were the worst that I've ever experienced. By Saturday night the aches and pains, fever, and chills were gone but I had unbelievable lower abdominal pains that just got worse with each hour. By 3 in the afternoon on Sunday I was so uncomfortable that I was in tears and Heather rushed me to the ER where they started to do tests right away. After a few hours of tests they finally gave me 5ml of Morphine which did nothing. Then they gave me 5 more which did nothing. Finally they gave me something that is supposed to be 14 times stronger than Morphine and that did the trick. I was admitted into the hospital and was there until late yesterday morning with a nasty bacterial infection in my intestines. I'm home now and supposed to take it very easy until I'm allowed to go back to work (if I feel up to it) on Monday. All the parts that Santa Cal sent are still sitting right where they were on Friday when I opened the box. I was hoping to work on getting started on the wiring this weekend but that probably will not happen now as I just can't risk it with this bug and wind up back in the hospital because that experience truly sucked.
Offline BLAC
  • An espresso is a
« Reply #1209 on: January 05, 2017, 10:05:18 AM »
Jesus, sorry to hear it, that sounds awful!
The way it was written I was half expecting the box you opened to be part of the cause for the reaction like the arc in Indiana Jones or something...
Feel better soon and get back to work, I love watching your build and have learned a lot from it
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #1210 on: January 05, 2017, 10:22:26 AM »
Sounds like Cal sent you the hantavirus along with that panel. Get well, man.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
« Reply #1211 on: January 05, 2017, 10:29:53 AM »
Glad you are out of the hospital, Chris!  Rest up.  There's still plenty of Winter left to finish.
« Reply #1212 on: January 05, 2017, 11:08:59 AM »
Lets be honest, Chris was overcome with a serious case of "Not-worthy-itis". Only once he was far enough away for a sufficient time from the marvels of my good deeds, could he finally recover to his cowering self. Kind of like Superman to Kryptonite apparently. Little did I (now I have to change my avatar to Lex Luther) that I have exposed a SuperHero Wannabe among us. Good thing JWilde left to make room for the next UberRider.  ;D ;D ;D
That's cold!
As Rick James (aka Dave Chappelle playing Rick) would say . . .
« Last Edit: January 05, 2017, 01:29:57 PM by CB750 Cafe Racer Fan »
« Reply #1213 on: January 05, 2017, 12:53:20 PM »
Yeah, age and treachery beats youth and strength ....9x out of 10
Chris, rest up...awful experience you don't want to repeat. At least you didn't eat some Christmas cookies from Cal before coming down with those symptoms.... then it might have been a little  hard to not bring the sights off Cal's center of mass.
Get well.
David
« Reply #1214 on: January 05, 2017, 01:29:27 PM »
When Chris re-emerges from his chrysalis, he's going to be re-cast a Motogadget acolyte replete with ferules and a crimper, and he will unleash a can of electronic whoop-ass on all of us.
Offline Restoration Fan
  • My wife will never call me
« Reply #1215 on: January 05, 2017, 02:03:30 PM »
LOL, epic responses from Cal and Don.
I echo the sentiments, Chris.  Rest and take it easy.  Plenty of winter time to work on the bike; don't make yourself sicker trying to do too much.
« Reply #1216 on: January 05, 2017, 03:43:21 PM »
Wow, is that what happens when you speak evil of BMW?!
I love BMWs!!!
Get well soon, Riverman.
Offline riverfever
« Reply #1217 on: January 05, 2017, 05:40:24 PM »
LOL!! Wow. I doze off and come back to this. For the record...I have had a case of not worthiness ever since all the Motogadget stuff showed up and I spread it across my humble bench. And...JWilde?? Seriously?? That's not just cold. That's a kick straight to the nuts with steel toe boots on a cold day. Haha. And I'm pretty sure what little guns there were have withered away after my stay in the hospital.
Thanks for the laugh guys. I needed it. I'm a little stressed about what I have, recovering from it, and making sure that I don't get it again. If I take antibiotics again I have a 33% chance for a relapse. The odds go to 50% and up from there.
« Reply #1218 on: January 05, 2017, 10:19:35 PM »
No clue how a bacterial infection is going to return with a dose of antibiotics...doen't make sense to me as it should be killed from the treatment, not just put into some kind of remission....the body creating antibodies to the bacteria.
Get well quick Chris, the fish want to torment and play with you....
Offline riverfever
« Reply #1219 on: January 06, 2017, 08:09:06 AM »
I'm no doctor but this is what I've learned by talking to doctors and doing my own research. As you already know, there's all different types of bacteria in the stomach/intestinal tract. Most of us have one bad one in our systems called Clostridium Difficile (aka C Diff). Our good bacteria keep this thing in line. However, over the last decade, this particular bacteria is becoming a problem in people for one very simple reason (which is precisely what happened to me). That reason is the rampant over use of powerful antibiotics. You go in to the doc with a simple sinus infection and get a script for Augmentin and take it for 10 days. Maybe it doesn't fully kick the infection so you get another 10 day script (entirely normal) and it's killing the good bacteria and, sometimes and in some people, the C Diff sees this as an opportunity and it rises up. It takes over. It causes the exact symptoms I had. The above scenario is exactly how I got in this situation.
Now I have all kinds of dietary issues to begin with. I'm diagnosed Celiacs, I'm highly allergic to dyes and certain additives that are in many foods, and high FODMAP food items (think very high fructose corn syrup) can really make me sick. If I eat an apple I'll be sick in 10 minutes. Certs breath mints (even two) make me sick for days (it's the dyes and additives in them). Minus the Celiacs, which I was diagnosed with about 4 years ago, I've had to figure this all out pretty much on my own over the last 3 years. I have very much become an advocate (for me) in the use of Eastern medicine (use of acupuncture and herbs to treat things as well as food). Eastern medicinal philosophy believes that the gut is the center for all good health. When the gut is in check, the rest of the body can fall in line but when it's not, you see other issues because it's all connected.
My primary care doctor (who I don't see very often at all anymore because I don't believe in his practices and I'm shopping for a new one if I go to one any longer at all) should have been telling me to overload my system with good bacteria while taking the antibiotics and that would have greatly reduced the likelihood of the C Diff going rogue. Since I've been out of the hospital, I take a particular capsule of probiotic twice a day that contains particular strains of bacteria that need to be in the body for the gut to be happy, and I intentionally eat foods such as ginger and sauerkraut (raw only as cooking it kills what I'm after) daily. Turmeric powder is also excellent and I use it on food like it's my job.
For someone who has already had a bout of C Diff, the risk of it happening again is huge. If I take another round of antibiotics (even two years down the road for a cut) I have a 33% chance for a relapse. After that it's 50%. It keeps going up from there. It's awful stuff and it's bad news. I'm gonna leave it at that because if I start talking more about what could happen I do tend to spin a bit. It's scary.
Offline BLAC
  • An espresso is a
« Reply #1220 on: January 06, 2017, 10:29:12 AM »
Oddly enough I worked in medical/tech for a couple years and am very familiar with C.diff and its growing drug resistance.  It is a very resilient little guy.  It is really REALLY important to finish your course of antibiotics whenever you are prescribed them, it doenst matter if you are feeling better, think you are over it etc, TAKE ALL YOUR PILLS.  Years of over prescribed and misused broad spectrum antibiotics have left us with some pretty nasty super bugs.  The good news is a lot of the "old classic" antibiotics that used to be effective in the past but are no longer used are starting to be effective again because the pathogens have grown and evolved to fight the newer medications but are unfamiliar with "the basics" essentially.
Just make sure you are working with good doctors with up to date info because it is a really fast moving topic in the medical field and people are doing studies and making breakthroughs all the time!
sending you positive vibes!
Offline riverfever
« Reply #1221 on: January 06, 2017, 12:22:28 PM »
Don't kid yourself BLAC. I'm thinking about hitting the streets to find another week's worth of the meds they have me on so I can take them a bit longer.
« Reply #1222 on: January 06, 2017, 01:34:42 PM »
Chris, thanks for taking the time to explain. I was not aware of CDiff and its issues.  Can't your doctors be convinced to humor you with another 10 day regime if you ask?  I hope you can whip this and get back to normal quickly. Sounds like you need a very clean diet with natural unrefined sources.  Might need to add a few fish to your diet as they would mostly be a clean source, no more than water and issues there that they live in.
Rest up and do the things needed for getting better.  The fish will miss you but they can find plenty to do to keep them busy until you are back.  Wonder if we need to find you one of those singing fish to keep you company... ;)  ;D
Offline riverfever
« Reply #1223 on: January 06, 2017, 02:10:52 PM »
Oh I KNOW my doctor would give me whatever I want. He's happy to throw pills down my throat. I just don't wanna see him anymore and that's the biggest reason why. And yes...my diet needs to be incredibly clean and that's one of the reasons why I've been trying to figure out if I could hunt. So I could know exactly what's been done to the meat I'm eating. My wife will not eat anything wild so I would think a deer or elk would last me quite a while. I'd like to stop in Bass Pro the next time I'm nearby and talk to someone about bows. Right now I do plan on trying to keep some fish this spring and through the summer but I'll feel better about that if I take them from a reservoir where they are stocked. We also have several reservoirs around here that have problems with Northern Pike taking over and anglers are encouraged to keep them but I have always let them go but I think that will change this year. I've heard they can be real tricky to fillet but I imagine even this one probably would have yielded a decent amount of meat.
« Reply #1224 on: January 06, 2017, 02:16:07 PM »
That whopper would feed you for a week.
