Author Topic: 1976 CB500/550 Project "Squirrel"  (Read 286967 times)
Offline riverfever
Re: 1976 CB500/550 Project "Squirrel"
« Reply #1800 on: September 12, 2018, 07:22:12 PM »
Really happy with how this turned out. I'll make a new tab this weekend and be just about ready to start on the gauge install.
F5B2EF05-6E4E-41E4-B436-1796A6E56E58 by cneumann2000, on Flickr
B74FC277-9CAB-4515-BA55-20824A9B6E73 by cneumann2000, on Flickr
« Reply #1801 on: September 13, 2018, 08:18:20 AM »
Not a bad job for hand-held Harbor Freight drill!
Offline riverfever
« Reply #1802 on: November 17, 2018, 01:16:29 PM »
Electrical question. I finished installing the Motoscope Pro several weeks ago and it works beautifully. This gauge calls for two 12 volt wires. The brown comes from AUX off the M Unit and wants a 1 amp inline fuse. This keeps the clock on the gauge working when the bike is parked. The red wire comes straight from batt POS and also needs a 1 amp inline fuse. This is the only difference I can see between the old analog gauges and the new one. One of the 1 amp fuses was bad and I swapped in a 5 amp after the install just to make sure things worked. Bikes been sitting now for a few weeks and M Unit won’t power up. Battery was showing 3.5V. It’s charging now but do I have a drain on the battery or maybe the battery is just done?
Offline riverfever
« Reply #1803 on: November 17, 2018, 02:51:51 PM »
Battery is a Scorpion AGM and it’s probably two years old and it did just get cold a few weeks ago so it could just be done. I have another one but it’s been on a shelf for about that long. Swapped it in and it shows 12V with key off but when I power up the M Lock and M Unit it drops to 8 and then the M Unit shuts off which it’s supposed to do when the vilts hit 8. I’ll charge this battery over night and see what happens in the morning. Bike does start with the kicker and volts show up to 14 when revving it. I disconnected the negative cable from the battery and switched my meter to amps and put one probe on negative cable and the other on negative post and the meter shows 0 so I believe there’s no issue with drain (be great if someone could confirm I’m doing that test correctly).
Offline riverfever
« Reply #1804 on: November 17, 2018, 03:05:25 PM »
I figured it had to be draining a tiny amount but that’s how Motogadget says to wire it in the manual.
Offline riverfever
« Reply #1805 on: December 08, 2018, 06:09:40 PM »
Ordered a new battery (Scorpion AGM) and everything is fine. Temps really dropped here so the battery is inside the house and on a trickle charger. Bike is prepped for a winter’s nap and under a cover.
I’ve seen the M Unit shut down upon hitting the starter button after hearing the solenoid click (because the volts are dropping to 8-9). This time the lights would not dance around the M Unit at all after waving the fob over the M Lock. The bottom three lights on input side would just faintly flicker. This is why I thought I had something bigger going on. Battery was showing 12 but I don’t know what the other specs were but didn’t really trust the battery because it was almost 3 years old.
Online RAFster122s
« Reply #1806 on: December 08, 2018, 08:13:01 PM »
Unless I were going to be riding this winter I would have delayed that purchase until spring when signs of the break in weather were apparent, how is your battery maintenance charger?
David
Offline riverfever
« Reply #1807 on: December 09, 2018, 10:14:35 AM »
Well I can see where you would think that. But because the battery was on the tender for two days and still wouldn’t crank the starter and because I wasn’t sure if there was another bigger issue that I would have to tackle over the long winter, ordering a $54 battery seemed like the smartest choice.
« Reply #1808 on: June 16, 2022, 07:28:10 AM »
Where are ya Riverdude?!
« Reply #1809 on: June 16, 2022, 09:49:39 AM »
He's busy fishing (now that the schoolyears is finished)!
« Reply #1810 on: June 16, 2022, 02:25:02 PM »
He should be ridin' now that the snow has melted!
Online RAFster122s
« Reply #1811 on: June 16, 2022, 07:29:13 PM »
Someone needs to print a fishing pole holder or two to mount to the shocks and then a luggage rack for the hip waders and other paraphernalia to be lashed down to, otherwise his fishing and acting as a guide will absorb all his riding time.
Will a cb750 get to his fishing holes or is he gonna need a  adventure bike?
« Reply #1812 on: June 17, 2022, 08:20:56 AM »
I think his CB500 will do just fine. I don't think he has to go far from his house.
