Author Topic: 1976 CB500/550 Project "Squirrel"  (Read 285012 times)
Re: 1976 CB500/550 Project...Read These Plugs
« Reply #450 on: November 02, 2014, 09:06:50 PM »
Keep an eye on the clip-ons from Tarozzi. Both riser clip-ons have a tendency to slip because the do not groove or index the mating surfaces. You can tighten the bolts to their max but the bars will sometimes slip out of position. It's a design issue.
Offline riverfever
« Reply #451 on: November 03, 2014, 06:20:51 PM »
Great. I wondered about that when installing them.
« Reply #452 on: November 03, 2014, 07:09:52 PM »
What's the plan for the triple top?  Looks like it's missing something.
Offline riverfever
« Reply #453 on: November 03, 2014, 07:11:20 PM »
That will eventually get replaced with a nicer one.
Offline harisuluv
« Reply #454 on: November 08, 2014, 10:48:33 AM »
This thread is so long so forgive if this has already been asked.  Are the current kits used still the K&L, with the exception of the emulsion tubes?  They looked pittet.
Also, you have a picture where you say it was right before you adjust the choke butterflies, then when they are installed on the bike, at least #4 is clearly tilted quite a bit, while #1 looks in the non choked position.
Offline riverfever
« Reply #455 on: November 08, 2014, 06:59:24 PM »
James...I ended up not using anything from the K/L kits but the gaskets.
The picture you quoted must be the camera angle.
Offline riverfever
« Reply #456 on: December 20, 2014, 04:00:28 PM »
Got this exhaust installed today. I must say that I didn't think I would ever own one of these. The fit is amazing. The welds are beautiful. The sound is unreal. I love the way it looks. The ONLY thing I'm a bit bummed about is the fender hits the headers. I know most don't run the front fender but I really like the way it looks. Not sure what I'm going to do.
Offline riverfever
« Reply #457 on: December 20, 2014, 04:28:25 PM »
I don't like the look of no front fender but I'm not sure how I want it to look yet. I like the look of this.
I think it would look strange to run the factory struts with the fender bobbed. Anyone have any ideas?
Offline riverfever
« Reply #458 on: December 20, 2014, 04:49:34 PM »
What about this?
« Reply #459 on: December 20, 2014, 05:00:05 PM »
I use a bobbed front fender with mine.
Offline riverfever
« Reply #460 on: December 20, 2014, 05:42:04 PM »
Thanks for posting that picture. After talking with Cal for a bit I'm wondering if it would make a difference if I rebuilt the forks (I'm sure they've never been rebuilt) and use progressive springs? I'd really rather keep the front fender as is. There's about 1 1/2" of clearance between the tire and fender. If rebuilding the forks wasn't enough I could modify the mount/brace but I'd also have to cut the struts, take a section out of each side and then weld them back together. That could be difficult.
« Reply #461 on: December 20, 2014, 05:45:53 PM »
I am a firm "believer" in rebuilding these 40 year old forks.  You can go with the progressives OR for a few $ more, I highly recommend the Race Tech springs and gold valve emulators, especially if you want a better ride and want to enjoy twisties.  I run the Race Tech set up and a fork brace with the bobbed fender.  It is a world better than the stock set up.  Anyone who says their 40 year-old forks are just fine doesn't ride their bike much.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #462 on: December 20, 2014, 06:08:44 PM »
I'm a fan of fenders too and unless you're planning on spending a lot of time riding in the rain, short fenders work fine.
Offline riverfever
« Reply #463 on: December 20, 2014, 06:36:29 PM »
I've always liked what you did with the fender Jimmy. I could bob mine like that. The rivets on the brace in the center are loose but I guess I could drill them out and do it again.
Offline Bootsey
« Reply #464 on: December 20, 2014, 08:36:24 PM »
What about this?
That looks good and keeps the stays, did you find that from a build on here? Might be one to copy.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #465 on: April 12, 2015, 08:24:25 AM »
Any updates?
Wondering about the front fender mod.  I'm trying to decide between a Carpy's 4 into 1 or MotoGPwerks pipe.
Nice to see a fellow Coloradan here with the same bike as mine.
Offline riverfever
« Reply #466 on: April 27, 2015, 07:11:23 PM »
Well the project sat for a while over the winter while I fished a lot but I'm motivated to work on it again. I have progressive springs, new seals, fork oil, and tapered head bearings on the way.
Nasty old oil.
Nasty old seals.
I've also started sanding the fork legs out and would like to buff them but we'll see how nuts I get as that job just plain sucks. Sorry for not seeing your reply Brett. I should know more about the clearance on the fender/header soon.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #467 on: April 27, 2015, 07:21:09 PM »
But Chris.... you're so good at polishing, I was thinking of sending you some parts from my bike! (I agree... worst job ever.)
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline riverfever
« Reply #468 on: April 27, 2015, 07:48:52 PM »
Haha. The real problem with the fork legs is all the nooks and crannies. One leg looks pretty good to 600 now but I'll go a bit more before I put it on a buffer and see how it ends up.
Hopefully after this I can ride it (although we got hammered with snow the last 2 days up here). I'll have to go back to square one and tune all over with the new exhaust but I really wanna hear it (heard it very briefly in the garage before walking away for the winter).
Offline riverfever
« Reply #469 on: April 27, 2015, 07:53:25 PM »
This is the leg I've worked on for about 3 hours now.
« Reply #470 on: April 27, 2015, 08:21:10 PM »
You're a good man, Charlie Brown. Polishing sucks. I woosed out and paid. Someone to do mine.
Offline riverfever
« Reply #471 on: April 28, 2015, 07:08:29 PM »
Thank you sir. Unfortunately, I have infinitely more time than money so I can't blow my wad on farming out things like this and save it for jobs like motor work and paint.
However...this does suck. In fact I may have coined a new term tonight while slaving away on these areas.
If something such as this and the areas around the castings is a pain the ass (and this certainly is) and it's also the current bane of my existence then...does this constitute a bane in my ass?
Offline calj737
  • I refuse...
« Reply #472 on: April 29, 2015, 04:27:13 AM »
Reaching the small recesses of the parts to be polished is why the good Lord invented children with small hands. Grab a neighbors kid off the street, strap some fine paper to their grubby little mitts, then commence whipping until you're satisfied those lowers are gleaming.
If you happen to thrash through the first abductee before you reach the desired lustre, no worries, there's plenty more where that little hellion came from.
Offline Tews19
  • I am no
« Reply #473 on: April 29, 2015, 06:19:13 AM »
Get a buffing wheel. Cost like 60-100 bucks. A brass wire wheel. Will strip them in a matter of minutes. Then buy buffing pads. Takes like 20 minutes to transform if done in 3 steps.
1970 Honda CB750 survivor.
« Reply #474 on: April 29, 2015, 11:47:54 AM »
I would add to Tews post that you may want to shop for a higher HP motor buffing wheel (check out Harbor Freight sales).  The higher hp models will speed up your polishing time.  You should be able to get a 3/4 hp model Central Machine buffer/grinder for about $80 right now on sale.
