Author Topic: Help- Advancer bolt broke  (Read 463 times)
Offline KennyRedman
  • 1976 CB550F, Indiana
« on: September 29, 2013, 10:37:05 AM »
How do I go about replacing this guy? It sheared of below. It's a 6mm x 55 bolt.
I was *this* close to finishing the bike too.
Re: Help- Advancer bolt broke
« Reply #1 on: September 29, 2013, 11:00:46 AM »
Drill and easy (hopefully) out it. A BOLT??? How'd that happen? Were you turning the engine with a 6mm vs the other end of the crank? And with the spark plugs in?? Those things will handle will only up to 9lb of torque. I'd almost bet a proper advance shaft is more hardened. Perhaps the smaller engines use bolts vs the 750? IDK. That sucks doesn't it.
Offline KennyRedman
« Reply #2 on: September 29, 2013, 03:28:03 PM »
Guilty as charged, but I got the bugger.
