Author Topic: Webcam DP 315  (Read 1398 times)
Offline Dion
Webcam DP 315
« on: October 01, 2013, 09:01:19 AM »
 &50 Sohc with Carrilo rods and 836cc pistons.
PLEASE, can anyone help with setting up the FDP 315.
With # 1 piston TDC and its tappets set to 0.050
I read the following on the deg wheel.
@ 53 deg BBDC the Exhaust Valve opens.
@ 39 deg ATDC the Exhaust valve closes. (supposed to be 23 deg)
@ 23 deg BTDC the Inlet valve opens
@ 69 deg ADBC the Inlet valve closes. (Supposed to be 53 deg)
What am I doing wrong.
PLEASE HELP
Offline BPellerine
Re: Webcam DP 315
« Reply #1 on: October 01, 2013, 09:58:36 AM »
if this is the repro rc 315 I think all the info is on the dynoman site.bill
1978 CB 750K ard and webers
another anfob
Offline Dion
Re: Webcam DP 315
« Reply #2 on: October 01, 2013, 10:07:43 AM »
hi, sorry typo dp 315 :)
Re: Webcam DP 315
« Reply #3 on: October 01, 2013, 01:34:59 PM »
Looks like the cam needs to be advanced
Re: Webcam DP 315
« Reply #4 on: October 01, 2013, 03:41:36 PM »
Tappets are set at .050.
 Is the .050not how far the valve moves..then you check the degrees?
Offline johno
Re: Webcam DP 315
« Reply #5 on: October 02, 2013, 02:56:00 AM »
Hi Man,
your cam is retarded............how much   39 -23 = 16 then divide by 2 = 8 degrees retarded  ( cos exh is biggest number)
I would advance the cam by 10 degrees so its 2 deg advanced.  How ? slot the cam sprocket or redrill the holes random and see if you get lucky  ;D    well at least put some thought into it with a protractor and try for 10 deg with hole centres  ;)
ciao johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline Dion
Re: Webcam DP 315
« Reply #6 on: October 02, 2013, 09:57:56 AM »
Sorted. Thanks chaps.  :)
Re: Webcam DP 315
« Reply #7 on: October 02, 2013, 12:29:22 PM »
Read my post on the Kenny Harmon cam. The guys gave me a lot of good info there.
Re: Webcam DP 315
« Reply #8 on: October 02, 2013, 01:16:35 PM »
Ohhh nooo, you're not getting off that easy  :D  You have to fill us in........
Re: Webcam DP 315
« Reply #9 on: October 06, 2013, 02:30:19 AM »
-Maybe different valve train lash?
I had to tight the valv adj screws until it almost lifted the valve to overcome the play in valve train and achieve correct readings.
After that I adjusted the valve lash to running lash and measured what I got and equal lobe centers
