Is the plastic material it is made of safe from gas attack?
It seems to be. Before making it, I put some in it over night and set it in a pan and found no change or softening. Also, fuel is never in there for more than, say 30 min. at a time anyway. I picked up some two part, threaded fittings at the hardware store. Bored holes in the bottle just slightly smaller than the fittings, put some JB weld around the hole (make sure you don't miss any spots), both inside and out, then screwed the two halves of the fitting together tightly and let it cure for a couple of days. Seems to work fine.. so far.
