Author Topic: cb500 master cylinder rebuild kit  (Read 2953 times)
Offline jgary
    • Catholic Nature Cards
« on: August 18, 2006, 08:46:43 AM »
Hi.  I picked up an CB500 that needs front brake work.  I've done this on a 750 before, with a master cylinder repair kit from Partsnmore.  I can't find a similar kit for the cb500 four.  There's one for the cb500 twin, but not the four.  Does such a beast exist for the four?  Thanks!
John.
1972 CB 750
1976 CB 750
Offline Mule Train
Re: cb500 master cylinder rebuild kit
« Reply #1 on: August 18, 2006, 05:24:28 PM »
I had the same issue with my 72 cb500. I called the motorcycle barn place and they didnt have a part number, I took a chance and bought one for the cb550 on ebay from some place called "pony  something" or "horse something". I measured everything with digital calipers and it was exactly the same. The return spring was longer because I think mine was worn. Ill try to find the ebay auction and PM you.
Offline jgary
« Reply #2 on: August 19, 2006, 06:39:17 AM »
Thanks!
J.
1972 CB 750
1976 CB 750
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #3 on: August 19, 2006, 08:12:53 PM »
You will find that most any master cylinder will work. It doesn't have to be Honda. You can actually buy a better master cylinder on Ebay that probably cheaper than the Honda rebuild kit.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline jgary
« Reply #4 on: August 20, 2006, 05:54:55 AM »
Turns out I still had the guts from the rebuild I did on the 750.  I'll use that to compare sizes.  Taking the 500 M/C apart was a lot easier-it was stored in a barn, not outside, so it wasn't nearly as dirty.  The only part that is definitely not reusable is the circlip, so I may have everything I need already.  Thanks!
John.
1972 CB 750
1976 CB 750
