Author Topic: Weepy inlet rocker arm ends....  (Read 2421 times)
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« on: August 19, 2006, 02:05:28 PM »
I rode the bike 600km one way to here last weekend and then jumped off and parked it. Haven't ridden it all week. Since it's a nice day I decided to check the valves and do an oil change.
Anyhoo, while I was warming her up before doing the oil change I noticed that there is a tiny amount of oil weeping from behind the inlet rocker-end bolts (at least that's what I assume they are)...the bolts with the allen heads (5mm?) just below the head cover.
Anyone ever experienced this before? Is it a question of re-torquing the bolts, if that is what they are? I don't have my manual with me to be able to see exactly how everything is configured.
Thanks, in advance, for any input.
Nick
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline 750goes
  • it will live
Re: Weepy inlet rocker arm ends....
« Reply #1 on: August 19, 2006, 02:34:40 PM »
If it is just the valve cover - tension them down just a tad more all around - wipe off the excess oil then inspect again after your next ride
has the bike been parked on the centre or sidestand
if on the sidestand does the oil leak on the leaning down side?
Offline nickjtc
« Reply #2 on: August 19, 2006, 03:53:00 PM »
It's definately not the valve cover leaking....new rubber gaskets all round. It's like it is actually coming out from behind the 'bolts' on the side of the head, which are congruent with the ends of the inlet rocker arm inside.
The bike has been parked on the centre stand all week.
« Last Edit: August 19, 2006, 04:01:23 PM by nickjtc »
1977 Suzuki GS750
Offline 750goes
  • it will live
« Reply #3 on: August 19, 2006, 04:39:49 PM »
download the manual from here - its in several parts
http://www.honda4fun.com/spaccati/spaccati.html
Ibsen
« Reply #4 on: August 20, 2006, 12:35:59 AM »
There is an o-ring oil seal in a groove in the rocker arm shaft cap bolt. It is probably leaking.
Offline puppytrax
« Reply #5 on: August 20, 2006, 05:33:58 AM »
His sig says he has a CB650, which I thought was evolved from the CB550, which has the o-rings on the aluminum cover at the side/end of the cam cover...is that bolt in the pic from a CB650??
I have those cover o-rings on my "to do" list, as I took the covers off and polished them, then re-installed the old o-rings (they are an odd size).   :-\
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline nickjtc
« Reply #6 on: August 20, 2006, 06:00:34 AM »
Got you on both forums, Ibsen. Many thanks!
1977 Suzuki GS750
Ibsen
« Reply #7 on: August 20, 2006, 06:17:12 AM »
Yes, the bolt on the picture is the end cap for the 650. It is bolted directly into the rocker arm shaft. The shaft itself is held in place in the rocker arm cover by a pin that fits into a groove in the shaft. This pin has a threaded end that is secured by a nut.
This is the CB650 rocker arm cover:
