Author Topic: Hello all New CB owner here.  (Read 2746 times)
Offline DarkRider
« on: August 20, 2006, 05:34:49 PM »
Hello all my name is Chris and i am from Lloydminster Sask Canada. As of Thursday i am the new owner of a 1974 Honda CB750K4. I purchased the bike for $250 and got a set of spare carbs and a Vetter Windjammer SS Fairing with the bike. Just managed to get the carbs installed using a couple of the tricks i found on here last night before registering onto the forum now i have a new problem to contend with. I am not getting any spark nor does the push button for the electric start work. I Can get the bike to turn over on the starter if i use jumper cables from my car battery directly on the pos lead to the starter on what i think is the solenoid beside the battery box. (its the round thing that the pos battery cable leads to then the pos lead off of the starter connects to the second post of. Not sure if its called a solenoid or not..used to a part that looks simular on a ford car hence why i called it that. Also the front lights are missing on the bike it isnt much of a concern unless the disconnected wires affect the ignition. However i was going to install the Vetter Fairing to take care of the missing lights once i determine what wire goes where. I ordered a Clymers manual for the bike and just waiting for it to arrive.
Anyway heres some pics of my 74.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline Roach Carver
Re: Hello all New CB owner here.
« Reply #1 on: August 20, 2006, 05:44:48 PM »
if you have the stock harnessthe wiring in the front should be self expanatory i.e. green to green, yellow red to yellow red. i would thing the only thing not hooked up would be the headlight which is one green, one blue and one white wire. everything else should be connected. the thing you are talking about is a solenoid. I think first get a good battery and start sorting out the wiring. good luck.
chris, I know someone from canada named Maggie. do you know her?
Just kidding.
« Last Edit: August 20, 2006, 05:46:37 PM by 71cb750 »
Offline DarkRider
« Reply #2 on: August 20, 2006, 06:36:50 PM »
Heres a couple more pics of the bike with the Windjammer Fairing mocked into place and the smaller purple fairing is one off of an 80 Suzuki GS750 that im considering making mounts to use on the CB..havent decided which i want to use yet
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
upperlake04
« Reply #3 on: August 20, 2006, 06:59:06 PM »
Welcome Chris - you're from the good side of Lloyd ;D  There are several active members from Sk - sometime when all the beasts are running well we should get together.  Anyway, this a great forum to learn and also be entertained.  A caution - don't reply to any pms asking how your freddy is dooin. ;D
Dave in toontown
Offline DarkRider
« Reply #4 on: August 20, 2006, 10:18:15 PM »
Thanx for the warning lol. Well im not sure which way im going with the bike...im leaning towards the sport touring look hence the possable use of the Windjammer but im not sure if that will fit in well with a straight pipe exhaust...or theres going with a mild cafe racer look using the GS 750 Fairing. At the moment its up in the air as to which way..chances are in the long run i will probably go one way for awhile then convert the bike later on just to keep it interesting.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: August 21, 2006, 05:39:49 AM »
I like the bungee cord holding up the kick-stand. ;D ;D
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #6 on: August 21, 2006, 10:04:38 AM »
Welcome to the site.
My opinion - loose the windjammer - as it kills the look of the bike .
But as I said , thats just my opinion...
Welcome again  ;D
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #7 on: August 21, 2006, 11:06:36 AM »
Welcome on board. You will find this forum a superb source of valuable information, and good for a laugh at times.
I agree with ProTeal; the sohc bikes look phenomenal naked and imho shouldn't be covered up.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
ElCheapo
« Reply #8 on: August 21, 2006, 12:00:26 PM »
Don't pick on him, you make due with what you have. ;D
Welcome to the board, you are in the right place. You have a good start and bought her at the right price. Maybe between rants we can teach you some stuff.  ::)
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: August 21, 2006, 03:04:42 PM »
Not picking at all. :)  Bungee cords are third on my list of all-time favorite quick fixes.  Just after Duct tape and baling wire!
I've got a piece of heavy guage copper wire in place of one of the hinge pins on my seat.  Put it there a couple of years ago, and it's worked so well I never replaced it! ;D
ElCheapo
« Reply #10 on: August 21, 2006, 03:07:24 PM »
 ;D ;D
Offline DarkRider
« Reply #11 on: August 21, 2006, 05:45:26 PM »
I'll do you one better, I have a paper clip in there.
Heh i can probably do you both better on that one..i have used nails for that purpose before..hell i have used various nails to replace cotter pins all over the place on dirtbikes lol
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline DarkRider
« Reply #12 on: August 21, 2006, 05:54:11 PM »
Well the more i look at the bike without a fairing of anysort the more i lean towards keeping it naked just as it is ment to be...then i dont have to worry about it looking wrong with straight pipes...Now the thing that gets me is finding replacement liights for my K4
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline mrbreeze
  • Not your average
« Reply #13 on: August 21, 2006, 07:27:33 PM »
Welcome Chris - you're from the good side of Lloyd ;D There are several active members from Sk - sometime when all the beasts are running well we should get together. Anyway, this a great forum to learn and also be entertained. A caution - don't reply to any pms asking how your eddy isfr dooin. ;D
Dave in toontown
       :D :D :D :D :D :D
MEMBER # 257
ElCheapo
« Reply #14 on: August 21, 2006, 09:23:08 PM »
Cotter pins??? What the hell are those  :o ;D
Offline DarkRider
« Reply #15 on: August 21, 2006, 10:08:19 PM »
Good question!! Ok...decided to keep the bike naked...need to find stock headlight and signal lights lol
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
