Author Topic: Rear Wheel Bearing Replacement  (Read 6277 times)
Nanahan
« on: August 21, 2006, 03:16:20 PM »
I got the rear wheel retaining ring off without much difficulty.  Now how do you get the bearings out?  It may be obvious, but before I get to hammering away I thought I would check here for any advice.  The bearings seem to be okay, but the seal is starting to deteriorate.  Does anyone know if Honda intended these bearings to last the life of the bike?  What about lubrication, or do you just replace them?  Thanks for any info or advice.
« Last Edit: August 21, 2006, 04:13:26 PM by Nanahan »
Offline 750duo
Re: Rear Wheel Bearing Replacement
« Reply #1 on: August 23, 2006, 09:56:50 AM »
If you are talking about the CB750 REAR WHEEL   ??? ??? ???
There are 3 bearings -Two 6304 ball bearings in the wheel and one 6305 bearing in the drive plate.
There are two retaining rings - one for the drive plate(the item the sprocket is bolted to) - one for the wheel itself
You can get all of them out by driving with a drift punch from the other side.
For replacement bearings you need to get the sealed bearings
6304 2RS----two
6305 2RS----one
Good Luck - Tom
1970 CB750 K0
1976 CB750 K6
1973 CB750 K3
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: August 23, 2006, 10:20:45 AM »
Tom - we are just about to undertake this job on Jim Shea's CB750F1 as there is about 1/4 inch movement in the wheel top to bottom.
Does the retainer have a left hand thread?
David Silver supplies bearings for £6 - any idea whether this would be a "set". If not, do normal commercial bearing suppliers recognise these codes?
Sorry for stealing your thread Nanahan but it looks as if we are trying to do the same thing...
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Nanahan
« Reply #3 on: August 23, 2006, 05:38:51 PM »
Yeah, the wheel is from a 74 CB750.  The retainer unscrewed from the sprocket side.  So you are saying drive all 3 bearings out from one side to the other.  Thats a long way to drive those bearings.  Just wanted to be sure before I grabbed the BFH and a drift.  Thanks for the input.
Offline jtb
  • An unlikely
« Reply #4 on: August 23, 2006, 06:34:05 PM »
Steve,  I got a replacement for the inboard countershaft bearing in the motor, it was $3.something US vs $8.43 from Honda.  I have read somewhere that the wheel bearings can be matched for less from any bearing supplier.  I just wish I had tried the same source for the outboard bearing on the final drive shaft before I spent $45.00 from Service Honda. :P :P :P
John
1977 CB750F
1985 V65 Sabre
Nanahan
« Reply #5 on: August 24, 2006, 07:52:37 PM »
I found that the final drive plate just pulls off.  After that the 6305 bearing is easily driven out.  The rear wheel retainer is then readily accessible and once removed the bearings also are easily driven out.
Offline Patrick
« Reply #6 on: August 24, 2006, 08:00:58 PM »
SteveD, those look like regular bearing codes to me. I've bought several bearing sets from local bearing suppliers using just the code, matching up the correct bearings for several bikes from the 60s and 70s. I don't think you should have any trouble. Give them a call. I always like to buy stuff locally when I can. It's more convenient for us and it keeps one or more of my neighbors working......
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #7 on: August 24, 2006, 08:04:03 PM »
How different is it to replace bearings on an F model with the rear disc?  Does it still have 3 bearings?
Offline Bodi
« Reply #8 on: August 25, 2006, 08:32:14 AM »
"So you are saying drive all 3 bearings out from one side to the other.  Thats a long way to drive those bearings.  Just wanted to be sure before I grabbed the BFH and a drift.  Thanks for the input."
No!
The outboard bearing is on the drive plate, take that retaining ring off and the plate comes off and then the bearing is pretty easy to press out. Both retaining rings have normal RH threads. Drill out the staking punch marks and make or buy a retainer wrench, bashing with a screwdriver in the notch is butchery... but you can still get the rings from Honda if you do ruin one.
The 2 in the actual wheel - you remove the second retaining ring first. There's a collar between the 2 bearings, you can slide it off centre enough to get a punch or drift against the edge of the inner race from the opposite side. Use a hammer and tap/pound around on opposite sides until it comes out. If you take the non-retained bearing out first then you can remove the collar and get easy access to the retained one, if you take the retained one out first you can push on the collar - use a wood or brass block against it it will be ruined if you hammer directly on the end - and get the other one out (the collar won't come out through the hole the retained bearing is in). Both have to come out their side, don't try to push one all the way through, this WILL NOT work!
Offline 750duo
« Reply #9 on: August 25, 2006, 08:27:42 PM »
SteveD   - Right hand thread-   Yes, these are standard bearing numbers. Honda originally used the 6304 z & 6305 z series bearings with a shield on only one side and a lot of grease. It is better to put in the 6304 2RS and the 6305 3RS bearings which are totally sealed on both sides - My bearing distributor (BDI) said they would outlast another 4 PO's.
Bearing prices - I got a whole set for both front and rear wheels (5 bearings) for under  $50 US
Groovie - Yes, the F model has 3 bearings. The drive plate uses the 6305-2RS and has a retainer -standard right hand thread. The wheel uses (2) 6304-2RS bearings but the retainer is on the disc side.
Tom
1970 CB750 K0
1976 CB750 K6
1973 CB750 K3
Offline MikeDeB
« Reply #10 on: August 25, 2006, 10:10:06 PM »
One final tip.  With a heat gun, heat the area of the hub that surrounds the bearing.  Makes it much easier to drift the bearings out.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Jim Shea
« Reply #11 on: August 25, 2006, 11:50:34 PM »
I'm glad Steve asked the Q on my behalf, because I don't understand the answers! God bloke ole Steve... and he's an electrical wizard..
