Author Topic: CB750 Alternator Wiring - 3 Yellows Does it Matter?  (Read 5281 times)
Offline RRRToolSolutions
  • I love old Japanese bikes!
« on: August 24, 2006, 04:35:52 AM »
Now that you've helped me identify my notched cover as being correct, can you tell me about these 3 yellow wires? 3 yellow males, 3 yellow females....I assume it won't matter, but something tells me to ask. Are there any measurements needed with a ohm meter or any distinction at all required to get these hooked correctly, or are they truely "random" ?
Thanks,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Re: CB750 Alternator Wiring - 3 Yellows Does it Matter?
« Reply #1 on: August 24, 2006, 10:32:19 AM »
Do we all agree, there is no difference?
Offline dusterdude
« Reply #2 on: August 24, 2006, 10:52:39 AM »
it would seem so
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #3 on: August 24, 2006, 11:28:45 AM »
Life with Kawasakis Mach III and Mack IV's has never been that easy. The 3 wires coming off the signal generator are color coded, but they stop at the engine. The wiring harness that carries the signals up to the 3 ignition coils under the tank all use the same color wires. You had to trace each cylinder's wire from the engine terminal up to the coil hook-ups using an ohmmeter or a continuity tester.
I learned the hard way that you don't just hook-up wires "just because they are the same" seems like in this case, the alternator does not care and works either way.
Thanks,
Gordon
Offline 750duo
« Reply #4 on: August 25, 2006, 08:54:07 PM »
We all agree - It does not matter which way you hook up the alternator YELLOW wires.
1970 CB750 K0
1976 CB750 K6
1973 CB750 K3
Offline 750goes
  • it will live
« Reply #5 on: August 25, 2006, 09:00:10 PM »
I think the resistance is supposed to be about 7.2 ohms...between any of the combinations of the wires
that is -  wires 1&2, 2&3, 1&3, thats irrespective of which way you have the leads connected on your multimeter
Offline Jonesy
  • Shop Rat
« Reply #6 on: August 25, 2006, 09:10:07 PM »
All three yellow wires deliver a phase of alternating current to the recifier and each one has it's own pair of diodes to sort out positive and negative charge. All of these feed back to the same place- the battery. So, it doesn't matter which one gets connected to which, as long as they are all connected to the rectifier. The rectifier sorts everything out from there...
Offline 750duo
« Reply #7 on: August 25, 2006, 09:15:40 PM »
NO  :o
The resistance of the FIELD COIL (White and Green) should be 7.2 ohms. Connects to the Regulator (White) and ground (green).
The resistance of the STATOR COILS (Yellow Wires)  should be 0.4 ohms between any two wires.
 ;D
1970 CB750 K0
1976 CB750 K6
1973 CB750 K3
Offline 750goes
  • it will live
« Reply #8 on: August 25, 2006, 09:25:05 PM »
thanks - I knew something down there had 7.2ohms
« Reply #9 on: August 26, 2006, 04:09:32 AM »
Guys, many thanks for the input and confirmation.
I'll postt some more pics soon.
Regards,
Gordon
