Author Topic: Installed Dyna Coils what did I do wrong  (Read 2486 times)
Offline 78whiteorbs
« on: October 05, 2013, 06:25:53 PM »
Keep popping the bottom fuse(main?) after installing dyna  5ohm coils. Take a look fellas and tell me what I did wrong. previously had stock coils with dyna S iggy. I tried keeping the exact same orientation that was on the stock coils. Now as soon as I turn the key pop... thought I followed the directions to a T.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Installed Dyna Coils what did I do wrong
« Reply #1 on: October 05, 2013, 06:36:48 PM »
OMG...  :o :o :o
You will blow a fuse every time you wire your hot leads to ground. Find the terminal connections on the coils for your yellow/blue (ground) and black/white (hot) leads.  ???
« Last Edit: October 05, 2013, 07:14:51 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline tlbranth
« Reply #2 on: October 05, 2013, 06:38:37 PM »
Can you diagram what you wired? Hard to tell what's what from the photos
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #3 on: October 05, 2013, 06:40:24 PM »
Two hints:  ???
1. The steel bar running through the center of the coil is continuous. Just connecting the hot and ground leads to opposite ends does not separate them.  :o
2. Look for screw terminals on the end of the coil for your hot and ground lead connections...  ;)
« Last Edit: October 05, 2013, 07:15:51 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #4 on: October 05, 2013, 06:49:26 PM »
Click on the picture for a larger image. Note the point of connection for the black/white stripe wires...  ::)  ;)
« Last Edit: October 05, 2013, 07:16:28 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline Tews19
  • I am no
« Reply #5 on: October 05, 2013, 06:59:27 PM »
Orbs does your bike have the 2 bottom frame rails cut off?
1970 Honda CB750 survivor.
« Reply #6 on: October 05, 2013, 07:02:49 PM »
You should find TWO screw terminals on the front of the coil. One is for the hot (black w/white stripe), the other is for the ground lead (blue or yellow) from the ignition. Orientation does not matter here, there is no polarity to the coils.
There are no connections to the grounding/mounting bar, although mounting the harness ground (green) at this location should not cause a problem, although the harness ground is typically attached at the coil bracket frame bolt.
« Last Edit: October 05, 2013, 07:17:21 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline brandEn
« Reply #7 on: October 05, 2013, 07:05:56 PM »
That black wire with the white stripe is switched HOT and comes from the kill switch. It connects to the coils. You have it connected to ground! You will pop a fuse everytime.
Offline 78whiteorbs
« Reply #8 on: October 05, 2013, 07:07:41 PM »
Not mine ,working on a friends bike(poor fella ;D), but yes. I have the cycle X weld in kit as well as some "knock off" Gordon style frame kit.  Whoever did it though looks like they used a portasaw and hardly left much more than a half inch maybe at the neck. might have to weld in some donor tube first...
I see what I did clearly now. Boy that's great. I was looking at what the stock coil looked like without thinking . Today was a long day. First hurrah with the dyna coils. Now to find were the juice taps in . You'd think those fine folks at Dyna would include a diagram but no such luck
thanks for setting me straight fellas.
« Last Edit: October 05, 2013, 07:09:45 PM by 78whiteorbs »
Offline brandEn
« Reply #9 on: October 05, 2013, 07:08:58 PM »
This might help.
This is the way I connected mine.
Left coil is 1-4 = Blue wire and black wire with white strip
Right coil is 2-3 = yellow wire and black wire with white stripe
« Last Edit: October 05, 2013, 07:11:28 PM by brandEn »
Offline 78whiteorbs
« Reply #10 on: October 05, 2013, 07:10:32 PM »
perfect thanks.
Offline brandEn
« Reply #11 on: October 05, 2013, 07:12:47 PM »
Sure thing!
« Reply #12 on: October 05, 2013, 07:13:10 PM »
DUH-OH! My bad, branden is right... the BLACK/WHITE are HOT. The yellow/blue from the ignition collapses the ground signaling the coils to fire.
Have fixed my previous posts now...
while eating crow. I at least knew you couldn't hook ALL the wires to ground!
« Last Edit: October 05, 2013, 07:18:07 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
