On the early 73s, 110 was stock. Honda later changed it to 105s was my understanding and what I've found when researching. 4th notch down from the top, second from the bottom was also the stock setting for the needles.
Regardless, what I'm most concerned about is why cylinder 2 is running extremely lean relative to my other cylinders.
Exhaust is questionable, but other than that crack on #2, they are in great shape.
What do you mean by intake? The carbs are keihin 657A.
The tank had some sediment, but I clean that out long ago, cleaned the petcock filter, and installed inline fuel filters so I could monitor the fuel. They are still clean as a whistle.
And yes, the jets are nice and clean.
