Author Topic: Question regarding carb and top end  (Read 586 times)
Offline Jimsun
« on: October 12, 2013, 11:32:27 AM »
Hey guys and thanks for taking the time to read and possibly help me address my questions.
Bike: 1974 CB550 full stock.
1. I'm planning on cleaning the carbs and replacing whatever necessary parts that typically needs to get replaced. Is it typically the gaskets that I need to replace when cleaning these guys? The PO stated that the 3rd carb needs to be cleaned because it overflows(?). Now i saw that for the 74-76 bikes, it's 4x  part number 16010-323-315 that i should buy
2. Will a 500 carb work on my 550? There's a guy selling a 500 carb and maybe it's worth just buying those and swapping it? (it is reasonably price).
3. I will be doing a top end gasket change (rebuild?) and I've read around here that the best gasket set is the CB550 Vesrah engine gasket. Is this true or is there an OEM set that i should go for.
4. Essentially I will be cleaning the carbs, top end rebuild (gaskets only?) and general clean up. Is there anything else i should keep in mind?
74 cb550
Re: Question regarding carb and top end
« Reply #1 on: October 12, 2013, 12:39:46 PM »
It's the rubber bits that need replacement because hey get to hard to reseal upon reassembly.  All these are contained in the kits you mentioned.
Yes, it will "work".  But, note the the internal parts and adjustments are tailored for an engine with less displacement.  Unchanged, the 500 carbs will provide richer mixtures in the low and midrange throttle positions when used on the Cb550.  These differences to often to subtle to notice for many, accept for diminished fuel economy, and spark plugs that develop more soot deposits.
If you are pulling the cylinder head cover off, pay attention to the installation warnings, lest you bend valves and ruin the valve guides.
Offline Jimsun
« Reply #2 on: October 12, 2013, 01:01:41 PM »
TT
Thanks. I suppose i will clean the carbs and save me the extra money and trouble of the 500.
I will make sure to keep a look up and take videos and pictures and doing the top end.
Any words for anyone about the vesrah gasket guys ? Is there an oem part number i can get a hold of instead? I'd rather go oem than aftermarket if it is affordable and reasonable.
Thanks in advance
74 cb550
