I probably shouldn't mention this since you already have all the parts installed, but for the next time....check out vintagebrake.com. There is a ratio chart for matching master cylinders to calipers. I use 15mm Nissin masters on my street CB's with dual stock calipers and the "feel" is indeed very wooden. The lever is firm alright and it's easy to find these master, but there are better choices. A large bore cylinder with small single live piston calipers takes far greater effort. Mr. Morse helped me and I have an 11mm master on my racebike. I really appreciate the two finger input, much improved feel.
Keep up the good work, you're going to enjoy it.
