Been a busy few weeks so have the frame ready for blasting, forks are disassembled ready for the new seals, o rings and boots I've ordered
Used bolt cutters to cut spokes off, rear wheel ready for new bearings.
Rims to be re chromed next week, new spokes from David Silver
Help I can't move the retaking ring on the front wheel
I've searched but not a lot of info on how to, is it reverse thread or normal - anyone advise?
Engine cases where sitting and spinning in a hot oil bath for 1 week, look nice al done at Heads Plus.
Crank looks within spec as does mains and rod journals. Ed at Heads Plus ( should be Ed's Heads) reckons will be ok. The head bearing surfaces and cam bearings will go ok Ed also reckons (Ed used to race CB500 back in the day), work shop is real old school with stuff every where but Ed knows his stuff, lucky to find him and only 10 minutes from home.
Start on carbies a next, new kits have arrived
Pleas help regarding front wheel someone
Bucket thanks for your offer, I need to go through every part I have and separate the god from the bad and ugly.
