so the thick black wire that goes to the starter on the cb550 is actually positive?
I guess that makes perfect sense, and I feel pretty dumb for having that connected to ground.. geez.
another question, without the solenoid, the main positive wire from the battery, can it be a smaller gauge wire? can it be say 14 gauge since the starter motor never has to draw anything from it?
The Red wire circuit between the Battery (+) and the rectifier (+) terminal needs to be either large, or made of a fireproof jacket like MTW or SXF jacketing, if you care to follow 'official' rules today. If you were to "build" a bike for someone, this has become [yet another overreach of] a fed regulation, so the bike can't catch on fire from wiring deficiencies. I make replacement fuseblocks for these bikes (multi-fuse versions after 1973) and had to go through all that [stuff] just to make them 'safe for mankind'.
If you make the Red wire 14-16 AWG in short length (less than 12" total to the rectifier), even with PVC insulation like you find at Auto Zoo (called "Automotive primary wire"), it should never actually get hot enough to be a problem. The main reason to use good wire jackets, though, is the weather and the alkaline soaps at the quarter carwash: both can make PVC brittle, and cold can make Teflon (THHN jackets) crack and split. So, try to find some SXL, GXL, or TXL wire, if you want best results. I think you can get small quantities of it from Del City and places like that.
The bike's loads beyond the rectifier are typically 11 amps or less, so a size 18 AWG will carry those loads with no issues, if it's not PVC.
