Author Topic: Compressor  (Read 864 times)
Compressor
« on: October 15, 2013, 05:28:13 PM »
This cheap compressor quit some time ago, finally took it apart - I was sure it was seized, but it was actually cracked frame. You can see it @ 3 o'clock. Due to the crack, the field moves the rotor off center and the motor will not spin
To prove it, I used C clamp to hold the tab and sure enough the motor run. For permanent -haha -  fix I driilled a hole and used a piece of wite. Looks like it holds, we shall se :)
« Last Edit: October 15, 2013, 06:50:17 PM by 70CB750 »
Re: Compressor
« Reply #1 on: October 15, 2013, 05:56:21 PM »
True shade tree fix there, CB70.
Air compressor?
Offline MoMo
  • Ride like you're invisible
Re: Compressor
« Reply #2 on: October 15, 2013, 06:04:37 PM »
Good old Yankee,  er Czech resourcefulness ;D...Larry
Re: Compressor
« Reply #3 on: October 15, 2013, 06:49:46 PM »
Yeah, air compressor.
I am sure Frank would cut a new piece from a chunk of 6061 and made it stronger than before  ;D
Re: Compressor
« Reply #4 on: October 16, 2013, 02:22:43 AM »
i smell smoke?
Re: Compressor
« Reply #5 on: October 16, 2013, 08:57:19 AM »
Can you put a small piece of flat bar over the crack, then. Driil and tap 2 holes, each side...?
Re: Compressor
« Reply #6 on: October 16, 2013, 09:32:51 AM »
I thought about it, but the ring is pot metal, didn't want to mess with it much.
Re: Compressor
« Reply #7 on: October 16, 2013, 04:09:58 PM »
J B Weld er up!
