Author Topic: Gaskets- will Neoprene work ?  (Read 1208 times)
Offline 750goes
  • it will live
« on: August 25, 2006, 11:22:16 PM »
I'm going to make an attempt at cutting a new gasket for my shifter cover, and probably a few others if needed.
Will neoprene be suitable for these covers
Shifter, Stator, Points & Clutch,
or should I use gasket paper ?
I think neoprene might maintain its flexibility longer than a standard paper gasket?
any thoughts or is this not a good idea?
Offline rab1dwolf
Re: Gaskets- will Neoprene work ?
« Reply #1 on: August 26, 2006, 12:48:52 AM »
thats actually a good question.  currently i dont have a gasket down on the rotor cover and would be insterested in cutting my own vs paying a ton for the custom sized one
1982 cb650sc nighthawk.  the work never stops.
« Reply #2 on: August 26, 2006, 08:41:52 AM »
Honda tend to use the thickness of the gasket to get the correct clearances so neoprene, being thicker, would not be a good idea
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: August 26, 2006, 08:45:38 AM »
I didn't think the shifter engine cover had a gasket - what is there to seal?  For the points cover, anything you want should be fine, as there are no clearance issues there.  Not sure about the clutch side - is there a gasket on that cover?
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #4 on: August 26, 2006, 10:34:09 AM »
If we're talking about a 750, the engine shifter cover definitely has a gasket. Quite a
lot of oil winds up in there....which is also why the shifter shaft seal occasionally leaks.
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
