Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Frank I am very sure the CBX and F2 bungs are the same. Pingel makes an adapter for the CBX which would make your life easier. I think it only takes a 1/4" Pingel fuel valve which are single feed only if memory serves correct. I am sure the single Pingel ( with a T fitting) would flow more than enough for you.
I put a Pingel single outlet on Purple Rain last week, screwed on to OEM fitting. F tank, or F2, not sure which,went rt on, Bill
This chart says the 79-81 CBX is 18mm. #A2003C adapter.http://pingelonline.com/powerflo_application_frames.htm
Quote from: MRieck on October 22, 2013, 11:54:40 AMThis chart says the 79-81 CBX is 18mm. #A2003C adapter.http://pingelonline.com/powerflo_application_frames.htm82' shows 20mm
Bear a Catholic,Pope well you know!!!!! would he miss it? Hell yeah,someones gotta take jim's place....watching me woek! not this yearLots to do between now and then!! Bill
Its not,last count @ 12! Go back to bed...not,back to work!! Bill
Quote from: Bill/BentON Racing on October 22, 2013, 09:10:38 PMBear a Catholic,Pope well you know!!!!! would he miss it? Hell yeah,someones gotta take jim's place....watching me woek! not this yearLots to do between now and then!! BillDoes this mean Big Jim is going to the Dragbike Nationals with Dave Fletcher?? First Jon Weeks and now Jim. Please don't tell me the band is falling aparts guys.
