Author Topic: Looking for non maintenance battery for cb550k  (Read 2221 times)
Offline gregripko
« on: October 21, 2013, 12:43:31 PM »
Looking to replace my 12n12a-4a-1 battery with a non maintenance battery... Any recommendations? Would like to pick it up from a local retailer.
Offline Bankerdanny
  • Endeavor to persevere
Re: Looking for non maintenance battery for cb550k
« Reply #1 on: October 21, 2013, 01:04:13 PM »
I believe that Autozone carries an AGM that fits the 550. I got the new battery for my GoldWing from them and they also had what I believe is the correct size for the 550.
Offline gregripko
« Reply #2 on: October 21, 2013, 01:06:02 PM »
Is it non maintenance?
Offline Untold
« Reply #3 on: October 21, 2013, 01:11:13 PM »
I got a Scorpion AGM battery and haven't had any charging issues since.  Highly recommended.
1976 CB550K
Offline gregripko
« Reply #4 on: October 21, 2013, 01:24:46 PM »
Is there a place I can pick up a scorpion at a local retailer?
Offline Untold
« Reply #5 on: October 21, 2013, 01:49:02 PM »
Not sure. I got mine online, but it arrived in a day or two.
1976 CB550K
Offline gregripko
« Reply #6 on: October 21, 2013, 01:54:42 PM »
Bought a scorpion online for $59.00 shipped.... Can't beat that :) ty
« Reply #7 on: October 21, 2013, 03:39:05 PM »
I picked up an AGM for my 750 from AdvanceAuto. Purchase online for 15% discount then go pick it up.
Offline Bankerdanny
« Reply #8 on: October 21, 2013, 04:01:44 PM »
Greg: yes, AGM batteries are sealed no-maintenance.
Offline gregripko
« Reply #9 on: October 21, 2013, 04:06:57 PM »
Looking forward to getting mine... Hear a lot of positive reviews about them... Now I just have to figure out why gas is coming out of my intake boot
« Reply #10 on: October 21, 2013, 07:54:44 PM »
Float valve not seating properly probably. Do you turn off your petcock at the end of a ride?
Offline gregripko
« Reply #11 on: October 21, 2013, 09:42:36 PM »
I do... I replaced the float valve needle today and when I raised the floats without the bowl it shut off the fuel.... Sorta stumped
Offline trueblue
« Reply #12 on: October 22, 2013, 03:34:25 AM »
I've got a MotoBatt AGM in my 650, it is over 2 years old and you can leave it connected for 6 months without touching it come back to it and fire it straight up.  I've never hooked a charger to it yet ;D
1979 CB650Z
Offline gregripko
« Reply #13 on: October 22, 2013, 09:40:51 AM »
That's awesome
« Reply #14 on: October 22, 2013, 11:28:56 AM »
Are the float levels set correctly? Does the float have a leak? Will the floats pivot up and down without binding?
Offline lucky
« Reply #15 on: October 22, 2013, 11:42:31 AM »
Batteries (all batteries) were considered non maintenience when they did away with removable caps on the top of the battery cells. That was many many years ago.
Do you mean a gel battery?
IF you mean AGM that is a GELL MATT technology battery. Meaning you can lay it on its side etc.,. Does not have liquid acid.
The charging characteristics of the gell batteries are different than lead/acid batteries.
Offline lucky
« Reply #16 on: October 22, 2013, 11:47:58 AM »
All batteries are non maintenience now.
It just means you cannot fill them yourself nw because they removed the screw caps over each cell of the battery.
Offline Untold
« Reply #17 on: October 22, 2013, 11:50:41 AM »
?? Then what about all the batteries I have that I had to fill on my own, and can remove the top caps?
1976 CB550K
Offline lucky
« Reply #18 on: October 22, 2013, 11:53:34 AM »
IF you set the float correctly by measuring like the book says (very important), then the only thing that it could be is a float bowl overflow tube is cracked, if the fuel is coming out of the float bowl drain.
Remember the book says ,"you must set the float by measuring BEFORE using the clear tube method.
You cannot set the float  so high that the gas in the bowl is higher that the overflow tube.
Offline gregripko
« Reply #19 on: October 22, 2013, 01:02:10 PM »
Fuel isn't coming out of the overflow at all... It's coming out of the intake boot between the carbs and engine head... It's not a lot but it's enough to see a drop hanging under the bowls screw by the morning and a small spot on the ground
« Reply #20 on: October 22, 2013, 02:39:50 PM »
Lucky, u smokin that #$%* again?!  ;)
Offline Bru-tom
« Reply #21 on: October 23, 2013, 02:53:56 PM »
so i can mount a Motobatt on its side then?
Black 750K8
« Reply #22 on: October 23, 2013, 04:40:13 PM »
What year?
http://www.batterystuff.com/kb/articles/battery-articles/battery-basics.html
Black 750K8
« Reply #23 on: October 23, 2013, 04:43:13 PM »
 ;D ;D ;D ;D
In between tokes read this.
Offline zeech
« Reply #24 on: October 23, 2013, 04:59:25 PM »
Probably not what you're looking for, but I've been using the Anti-Gravity 8 Cell for 2500 miles now with zero hiccups. Never have to charge it. Never have to worry. I also upgraded to a modern regulator/rectifier. Some people have had bad experience it seems, but mine is flawless. And it's freaking tiny and lightweight.
