Author Topic: Sidecar  (Read 178971 times)
Re: Sidecar
« Reply #50 on: May 04, 2018, 04:53:22 AM »
I tooled up some :)
Re: Sidecar
« Reply #51 on: May 04, 2018, 04:59:45 AM »
I could not find a way to bend DOM tubing for the swan neck connecting bar, so I just welded it up like this.
Re: Sidecar
« Reply #52 on: May 04, 2018, 08:48:48 AM »
Nice, before I got my mill , I knew I needed a boring head.. sure use it a lot..
 You may need to regrind the boring bars, make sure they have clearance.
 On aluminum I use HSS a lot in a bar with setscrew to hold the toolbit.
 Now you can make more stuff. .
Re: Sidecar
« Reply #53 on: May 04, 2018, 08:54:08 AM »
Thats the point :)
Just looking over all those hole saws I used to use  ;D
Re: Sidecar
« Reply #54 on: May 04, 2018, 11:59:27 AM »
 My brother got a 500 with a sidecar. Holy wow that thing's got a ton of angle iron and heavy brackets welded to the bike frame. One of the big ones was left off to make clearance for the kick start. I doubt it's even needed.
`1
« Reply #55 on: July 21, 2018, 03:14:38 PM »
Working on the wheel swingarm now.
Re: Sidecar
« Reply #56 on: August 02, 2018, 06:19:58 PM »
The stud for the swingarm pivot.
Re: Sidecar
« Reply #57 on: August 03, 2018, 08:58:26 AM »
What a stud!
Re: Sidecar
« Reply #58 on: August 03, 2018, 10:18:36 AM »
I am copying Velorex frame, more or less.   From what I could find, heavier sidecar is always better, that stud is a tube with a 1/4" wall.  There will be plenty of meat on this one  ;D
Re: Sidecar
« Reply #59 on: August 03, 2018, 12:37:09 PM »
Are you going to run a small gusset  between bushing and frame ?
Re: Sidecar
« Reply #60 on: August 03, 2018, 05:10:31 PM »
Yes, I plan to.
Re: Sidecar
« Reply #61 on: August 03, 2018, 05:57:00 PM »
What are you going to do for a body, Prokop? I stumbled across this today:
https://phoenix.craigslist.org/evl/mpo/d/1980s-dmc-sidecar-for/6660651739.html
Re: Sidecar
« Reply #62 on: August 04, 2018, 02:51:51 AM »
Thank you, scottly.  Bit far  ;D
I plan to use it for cargo first and eventually build up something like this.  Plans of mice and men,  haha.
Offline jgger
Re: Sidecar
« Reply #63 on: August 04, 2018, 08:48:17 AM »
First pic reminds me of my avatar ;D
Offline Gurp
  • I'm no.......
  • Once was a...
Re: Sidecar
« Reply #64 on: August 12, 2018, 08:27:15 PM »
Sweet build Dorothy will love her companion.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Re: Sidecar
« Reply #65 on: August 12, 2018, 09:21:53 PM »
Scottly, dmc sidecar?  Deloren Motor Cars?
Back to the Future if you can hit 88 mph with your sidecar...
Re: Sidecar
« Reply #66 on: August 12, 2018, 10:15:47 PM »
In second gear ?
Re: Sidecar
« Reply #67 on: August 13, 2018, 01:03:04 AM »
Frank, That would have to be a 450 powered or was it a 350 powered JWilde sidecar...
I am not a JWilde historian or is it a fiction-ian so, please correct my misinformation if any exists...
David
Re: Sidecar
« Reply #68 on: August 13, 2018, 01:16:11 AM »
https://tucson.craigslist.org/mpo/d/csc-sidecar-friendship-iii-obo/6656129832.html
Another too far away...
Sidecars have had a resurgence in interest by the hipsters..at least they are keeping a segment of the industry afloat.
    • http://forums.sohc4.net/index.php?PHPSESSID=n8ebc51vj7etnf1l4n8bb8csc0&/topic,60973.0.html
Re: Sidecar
« Reply #69 on: August 13, 2018, 05:49:52 AM »
a Danish nimbus..drive as a tractor 750cc.ohc engine, and shaft drive... runs good for a 1930 konstruktion...the generator shaft drives the overhaning cam .. 90 deg.. gear driven..
« Last Edit: August 13, 2018, 05:52:19 AM by strynboen »
Re: Sidecar
« Reply #70 on: August 13, 2018, 08:14:38 AM »
In this book:
https://www.ken-follett.com/bibliography/hornet_flight/
the hero drives Nimbus converted to steam or maybe wood gas powered.  Good story, based on an actual historical event.
Re: Sidecar
« Reply #71 on: August 13, 2018, 09:47:44 PM »
My brother bought this, it has about a half ton of angle iron welded to the 500 for mounts. ironworker style. He'd like me to move this to his bought new K4 750 but that ain't happening unless he rides this a lot. https://photos.app.goo.gl/9Wtq2dZNq41J7ZES9
 Notice how he parked me in the mud puddle. I may have mentioned he wasn't allowing for the width of the sidecar and would probably put us both in the hospital. grumpy old men. lol.
« Last Edit: August 13, 2018, 09:49:49 PM by Don R »
Re: Sidecar
« Reply #72 on: August 16, 2018, 01:38:39 AM »
You rode in his new sidecar? It have a damper on the front steering or something else going on?
Re: Sidecar
« Reply #73 on: August 16, 2018, 08:30:28 AM »
Wow! That looks fantastic.
I've always wanted a sidecar, but don't have the garage space.
Re: Sidecar
« Reply #74 on: August 24, 2018, 05:51:27 AM »
Just saving a picture  :)
