Author Topic: Carb Jets  (Read 4229 times)
Offline Magilla
  • My bike: 1976 CB750F
Carb Jets
« on: October 26, 2013, 09:14:31 AM »
Because you guys know how to find everything that is Honda . . . . .
Can anyone point me to a source for the jets for a 1972 CB350 (2 cylinder)?  the jets for this bike are press fit and do not screw in.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Re: Carb Jets
« Reply #1 on: October 26, 2013, 09:46:11 AM »
Sirius consolidated inc is one place, but look up the part number on cmsnl, and then enter that number in a search bar.  It will come up with plenty of purchase options.
« Last Edit: October 26, 2013, 09:50:39 AM by flybox1 »
"This is my CB. There are many like it, but this one is mineā€¦"
Offline lucky
Re: Carb Jets
« Reply #2 on: October 26, 2013, 10:05:58 AM »
Something is wrong with this question.
The 1972 CB350 did not have push in jets. The push  in jets did not happen until much later on. You do not have to replace jets unless they were damaged .
It is not a normal routine to replace a brass jet. They last almost for ever.
You can tell how many cylinders a motorcycle has by counting the exhaust pipes coming out of the cylinder head.
You did not say WHICH jets you are looking for.
The CB350F (four cylinder) that happened much later has jets available from Bike Bandit .com.
Re: Carb Jets
« Reply #3 on: October 26, 2013, 03:48:12 PM »
Actually Lucky it does look like they do indeed use the press in jets on the 350 twin and also the CB350F or four cylinder was made from 1972-74.  http://www.ebay.com/itm/TWO-Honda-CB350-CL350-Twin-2-cyl-K-L-Pro-Carburetor-Carb-Rebuild-Repair-Kits-/400588100224?pt=Motorcycles_Parts_Accessories&hash=item5d44e95280&vxp=mtr#ht_721wt_992
« Last Edit: October 26, 2013, 03:52:14 PM by ekpent »
Offline jheck10
Re: Carb Jets
« Reply #4 on: October 26, 2013, 06:11:03 PM »
Ordered from jetsrus.com last week.  Affordable and fast.  What more could you ask for?
1976 CB750K, 2007 VFR800, 2006 ST1300A! 1973 Kaw z1, 1980 CBX, 1967 HD ElectraGlide
Offline brewsky
Re: Carb Jets
« Reply #5 on: October 27, 2013, 01:21:26 AM »
Not necessarily true.... there are several singles with dual exhaust, (including some with dual carbs) from honda, yamaha, bmw, royal enfield etc.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Online dave500
Re: Carb Jets
« Reply #6 on: October 27, 2013, 01:48:14 AM »
hey lucky how old are you?
Offline 750K
Re: Carb Jets
« Reply #7 on: October 27, 2013, 02:14:49 AM »
^^^Bahahaha, good one dave
77 Cb750, 78 Kz1000
Offline Magilla
Re: Carb Jets
« Reply #8 on: October 28, 2013, 03:56:14 AM »
Yes I can count cylinders on a bike.  I said it was a 2 cyl just incase someone was going to assume it was an F series (4 cyl).  Again this is a 2 cyl bike.  It DOES have PRESS in jets in the TWO carbs that are on the bike.
Although you dont often have to replace them, there can be issues.  The jets have a built in seal/oring and when it gets old and dry it does not work so well.  The jets I have no longer stay in place due to bad seals.  Thus I need new jets.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Re: Carb Jets
« Reply #9 on: October 28, 2013, 05:22:28 AM »
Bet someone here knows where to find those O-rings or their size, seems there is a possibility they are the same size as the fours.  ;)
Offline Magilla
Re: Carb Jets
« Reply #10 on: October 28, 2013, 07:25:40 AM »
I agree that the oring is likely still available but the jets are in rough shape.  It looks like some idiot thought they are screw in jets and mauled the crap out of them trying to get them out.  Although still usable I thought it best to replace them while the carbs (2 carbs) are apart.
Oh yeah, by the way, I am that idiot that tried to unscrew the jets!!
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline lucky
Re: Carb Jets
« Reply #11 on: October 28, 2013, 08:58:23 AM »
That is WHY I said,"at the cylinder head".
Offline lucky
Re: Carb Jets
« Reply #12 on: October 28, 2013, 08:59:59 AM »
Looks like you are right.
Sorry for the mistake.
Online dave500
Re: Carb Jets
« Reply #13 on: October 28, 2013, 12:38:34 PM »
at the cylinder head lucky is where dual exhaust ports can be found on a single cylinder.
Re: Carb Jets
« Reply #14 on: October 28, 2013, 08:05:32 PM »
Here are a couple of pics of dual exhaust "at the cylinder head" of two Honda singles..
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Carb Jets
« Reply #15 on: October 29, 2013, 10:45:19 AM »
The seals/o-rings that go on your jets come as part of Honda's gasket kits, p/n 16010-286-004 @ ~$13/ea from Honda.
Offline Magilla
Re: Carb Jets
« Reply #16 on: November 13, 2013, 04:29:46 PM »
Anyone on here know what the factory jet sizes are for this 1972 CB350K?
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline tbpmusic
Re: Carb Jets
« Reply #17 on: November 13, 2013, 07:45:29 PM »
« Last Edit: November 13, 2013, 07:47:30 PM by tbpmusic »
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
Offline Magilla
Re: Carb Jets
« Reply #18 on: November 14, 2013, 03:45:11 AM »
Jets on order.  Thanks for your help.
Now I just need to add heat to my shop and I can work on the bike.  Its been in the 20s (F) here this week.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Re: Carb Jets
« Reply #19 on: November 14, 2013, 08:49:50 AM »
Magilla,
  I also have a 72' CB350 twin which came w/ #68 small(primary) & #105 (secondary) main jets.I also ordered jets from jetsrus.com;I ordered the #70's to give a slight increase in the cold naturedness of my bike.I noticed that the O-rings that come on these jets are a bit too big & leaked after I tried "squeezing" them in a too small opening.Their jets are great but the supplied O-rings aren't.
I think what Tugboat said about the O.E. Honda kits is highly recommended...,if nothing else but to have spares after your too large supplied O-rings swell up & cause the bike to run too rich.I'm running sealed stock O.E. exhausts & enjoy the #70 primaries quite a bit;I think it's better w/ them because the Ethanol fuel leans the system out some.
Offline Magilla
Re: Carb Jets
« Reply #20 on: November 15, 2013, 03:54:22 AM »
I will be running open headers with no mufflers on this one.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Re: Carb Jets
« Reply #21 on: November 15, 2013, 12:34:51 PM »
Magilla,
     You'll probably need to go bigger on the jets than my stock O.E. #70 & #105...
Offline Magilla
Re: Carb Jets
« Reply #22 on: November 27, 2013, 07:41:45 AM »
I put the jets in and now it wont start.  I pulled it all back apart and did it over again and it did not start.  I put starting fluid down its throat and it did not start.  It ran on 1 cyl when I brought it home so at minimum it should in theory, still run on the 1 cylinder.  I'm sure its something stupid I am over looking.  I should have time on Friday to work on it again.  It will run again.
BTW, having a heater in my shop:  Priceless!!
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Re: Carb Jets
« Reply #23 on: November 28, 2013, 10:56:40 AM »
A Heated shop..,YES !  ;D
Offline Magilla
Re: Carb Jets
« Reply #24 on: December 10, 2013, 07:15:33 AM »
It finally fired on both cylinders a few weekends ago.  It only ran for a brief time but it showed life on both sides.  Now I need to run new cables, put new fuel lines on and then fire it up again.  I feel pretty good that it will run now.
Once its running right I will have to decide what to do with the bike.  I could tear it apart and restore it.  The negative to that is that I will never get my money back out of it.  The other thing I could do is "arrest" the decay.  That keeps it in the state of a barn find and does not let it get any worse.  I am more inclined to go that way with this bike.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
