Author Topic: Pilot Jets?? - size 40  (Read 1509 times)
Offline 750goes
  • it will live
« on: August 28, 2006, 12:45:29 AM »
Anyone got an answer to this
Do the standard pilot jets for a 750 being size 40 have a hole that goes straight through the lenght of the jet??
The reason I ask is that I have cleaned these things a few times and the holes in the jet are clear from side to side on the main shaft, but trying to see through them from end to end seems to not happen.
I can use a fine wire to poke down from each end but never seem to go the HOLE way through  :) :)
thanks for your replies
Offline Jay B
Re: Pilot Jets?? - size 40
« Reply #1 on: August 28, 2006, 04:55:53 AM »
Yep there should be a hole straight through. They can be a bear to clean. Soak in carb cleaner for several days. I used a single bristle from a steel brush to clear mine. Don't get too agressive, the hole is tiny and precise, if you ream it out it will run rich.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
« Reply #2 on: August 28, 2006, 05:01:08 AM »
Another method to try is heating them to near glowing with a propane torch. This seems to turn the blockage into dust and then can be more easily cleaned.
Offline carl550k
  • 76 550k, 99 honda shadow aero
« Reply #3 on: August 28, 2006, 08:31:40 AM »
does the same apply to 550k pilot jets? size 38? thanks carl
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: August 28, 2006, 09:58:54 AM »
Blow through them and make sure they are dry. Hold them up to a bright light source. Any wet carb cleaner or gas in the jet will make it appear blocked. If you can get a wire through it I would think you would be able to see some light through the opening.
Offline StevieMac
« Reply #5 on: August 28, 2006, 10:56:45 AM »
Yes.  There should be a hole right through the center.
I've had great results soaking jets in Yamaha combustion chamber cleaner.  Any Yamaha dealer should have it and IMO it works great.
72 CB500 Cafe
78 CB750 Chopper
Gallery: http://www.sohc4.us/gallery/v/members/personal/StevieMac/
Offline Master Ted
« Reply #6 on: August 29, 2006, 07:37:15 PM »
I second the Yamaha carb cleaner - it's purported t/b especially good at dissolving varnish while still easy going on seals. I stripped my 'gang of 4' just yesterday and soaked overnight in Yamie' solution. A blast of compressed air cleared a couple of my still clogged 40s.
Reassembled the whole affair this morning and am quite pleased how clean everything looks inside and out!
CB750/K2
Offline 750goes
  • it will live
« Reply #7 on: August 30, 2006, 12:03:56 AM »
I borrowed a very small braid of stainless steel wire - unravelled a length and poked and prodded and twisted it through the pilot jets, then because the wire was "wavy" in appearance, I ran this back and forward while gently rolling the jet around the wire about 20-30 times.
They are now clearer than before...so will give them a try after I put on some new clamps for the carb boots. :)
