Author Topic: Valve timing half done?  (Read 1082 times)
Offline nitrofish1
« on: October 29, 2013, 05:19:55 PM »
Assembling my top end, i threw away my ignition plate cuz i was going to replace it, so i only have half of the things to time it to as per the Clymers and factory manual.
So my question is, can i align the cam tang with the cam holders with cylinders 1,4 @TDC and be ok with just lining up the ignition timing later? Until i know i can go no further with installing rockers and top end  :'(
Offline City Boy
Re: Valve timing half done?
« Reply #1 on: October 29, 2013, 05:24:02 PM »
Hi.As long as you have the advance unit installed,you can set the cam timing as per the manual.
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline nitrofish1
« Reply #2 on: October 29, 2013, 05:54:20 PM »
i still have the spark advance unit, did not even consider that. Thanks
