Author Topic: Stock 4-4 exhaust. Now new no no's.  (Read 74443 times)
Online Don R
Re: Stock 4-4 exhaust discussion. Not now, no New nono's!
« Reply #125 on: November 05, 2021, 10:26:40 PM »
 I noticed Z1 has replica Kawasaki 4-4 exhausts, that may be a good sign because PMC makes them and also cb750 pipes however I think PMC makes the 341 style. Ebay said Z1 had 5 sets and sold 5 sets.  Webike still says sold out and I haven't gotten an email yet.
 If I ever got caught up on cb projects I'd like to Z1 clone my 80 kz1000. Orange/brown with 4-4, flat seat, I got the carbs recently and can find the correct airboxes. Repro shocks with the reflectors are out there, the forks with reflectors are difficult to find.
« Last Edit: November 06, 2021, 09:09:23 AM by Don R »
« Reply #126 on: November 05, 2021, 10:35:10 PM »
BenelliSEI, you got the Lotus Root pipes that are very open inside? For the first Sandcasts.
Yamiya sold them for 250.000 yen.
Baffle look like a bomb ;D
They have a darker tone than the Yamiya No numbers that look like HM300 pipes, Yamiya price around 150.000 yen when I ordered.
They have also good flow and nice sound without the "wool". HM341's are very restrictive.
« Last Edit: November 06, 2021, 12:08:15 AM by PeWe »
« Reply #127 on: November 06, 2021, 05:50:55 AM »
PeWe….. I haven’t opened the carton yet! They are HM300 with no numbers.
Online Don R
« Reply #128 on: November 06, 2021, 09:06:46 PM »
  Just once, pull out the baffles and take it for a ride!
« Reply #129 on: November 07, 2021, 01:21:06 AM »
They sound very nice with baffles in without the thick padding around. Rather loud after 120km/h ;D
My brown K2 has those that way.
My K6 with Hindle 4-2-1 sounds less when cruising in legal speeds. Different when twisting some ;D
« Last Edit: November 07, 2021, 01:23:05 AM by PeWe »
Online Don R
« Reply #130 on: November 07, 2021, 08:47:19 AM »
 I have one baffle with the front end drilled for an O2 sensor. It's tempting to drill them all. That said, I already have jetting issues.
« Reply #131 on: November 07, 2021, 10:34:34 AM »
Buy a new one nit drilled. Use the drilled one for the AFR tests.
I guess baffle without padding will make difference mostly on main jet compared with no baffle.
If running to lean needles easy to fix by overcompensate with 1 size too large main. It will show in way too rich at higher speed, after 140kmh and WOT.
That's how I found out to lift needles 1 step (4) and go down on main to 115 from 120.
Stock airbox.
I removed  all baffles when running the Yamiya No numbers on dyno with 1005cc. 2 sensors each tlme. 2 runs, AFR on all 4. (1-2 + 3-4)
After that a power run with all baffles in. If it ran a little lean on main jet, I guessed it will be OK with baffles in.
Not accept the slightest to  the rich side without baffles.
Last time on my K2 only measure power, we both felt it ran OK. CB750 carbs not much to adjust since they are made for the engine. Needle height and main jet which I had tested out by road tests, needle could only be one, main tested leaner and richer.
« Last Edit: November 07, 2021, 10:40:16 AM by PeWe »
Online Don R
« Reply #132 on: November 07, 2021, 03:58:23 PM »
 I do have a spare baffle, that's the drilled one. I rode with them out today after returning to original jetting and adding the carb top gaskets. Now it's too loud with no baffles in the no no's. That's a good sign.
Online Don R
« Reply #133 on: November 22, 2021, 05:52:17 PM »
 Webike took the M Tec Chukyo 4-4 (no number) pipes off of their web site. Either there won't be any more or they are sick of the inquiries.  PMC are still listed as out of stock, I think they are the 341 style.  DSS no listing and Yamiya none in stock.
« Last Edit: November 22, 2021, 06:41:59 PM by Don R »
Online Don R
« Reply #134 on: November 24, 2021, 03:28:20 PM »
 I put a set of CSMNL 341's on my gold "nugget" K0 today. I'd prefer to put them on my brothers K4 later on, but for now they have a home.
« Reply #135 on: December 04, 2021, 01:41:30 PM »
Don..... what was the last price you saw on a new set of “nono’s“? I paid highly for the Yamiya set from Calgary, but don’t regret it!
Online Don R
« Reply #136 on: December 04, 2021, 02:41:42 PM »
 My no no.s from DSS were around $1400, the 341's I got from cmsnl were around $1850 with trim. Around the time you got yours, DSS showed a few sets in stock. It was too late for a heads up to you, and I stupidly didn't order them when I saw them, the next day they were gone, and they have not had any since.  I think they had been stuck in the suez canal!
 My first set of Yamiya were from one of the ebay sellers, Mach IV motors if I recall correctly.  I sniped them for $1200 and they stopped selling them after that.
   I still think Yamiya's are made by M Tec Chukyo which is related to Mugen, which is/was owned by Mr. Honda's son. He made a prototype of a Vincent clone a couple decades ago, tried to get it into production. There is a welding shop in Japan that makes the 4-4 Yoshimura Daytona copy per order when they can.
« Last Edit: December 04, 2021, 02:46:30 PM by Don R »
Online Don R
« Reply #137 on: December 04, 2021, 02:47:27 PM »
« Last Edit: December 04, 2021, 02:57:25 PM by Don R »
« Reply #138 on: December 04, 2021, 09:18:24 PM »
Stunning!
Online Don R
« Reply #139 on: December 04, 2021, 10:01:16 PM »
 I saw the guys on American pickers buy a Vincent engine. I knew Mike already had a buyer for it even if I could afford one. But dang. He also got a knucklehead engine right out of a pickup truck I had walked past the day before. I could get a frame built if I had one.
Offline 69cb750
« Reply #140 on: December 05, 2021, 06:09:03 AM »
I bought a bike Mike wanted to buy.  I was in the right place at the right time with money. I'm still pretty happy about it.
Most all the revivals have failed, Polaris seems to be the only success.
« Last Edit: December 05, 2021, 06:10:47 AM by 69cb750 »
Offline 69cb750
« Reply #141 on: December 05, 2021, 06:14:38 AM »
Offline 69cb750
« Reply #142 on: December 05, 2021, 06:15:35 AM »
Offline 69cb750
« Reply #143 on: December 05, 2021, 06:16:50 AM »
Online Don R
« Reply #144 on: December 05, 2021, 08:04:54 AM »
 A friend bought a 46 Indian chief from Mike before he got on TV. It's gorgeous. Anyway my point was I think Honda still has a connection to some of these parts even if it's a decendant company.
« Last Edit: December 05, 2021, 08:08:16 AM by Don R »
« Reply #145 on: December 05, 2021, 10:40:24 AM »
I wonder when the production  of 4-4 will start again.
The Yamiya no numbers the type that fits most bikes and work really well.
I'm happy about my expensive Lotus Root pipes I bought from Yamiya (250.000 yen + shipping + VAT + customs when the rate was better for me 2017).
Maybe back on my K6 again or a 3rd build.
Now when not available it feels good to have an extra set.
They cannot blame Covid now, or do they?
Online Don R
« Reply #146 on: December 05, 2021, 12:20:52 PM »
 I haven't heard reasons why none are being made. I had hope when DSS showed a few sets, but they vaporized overnight.  My friend in the aftermarket says there are supply chain problems, like getting material and our parts are made part time in factories when they are caught up with their normal work.
  Indonesia says their manufacturing base may never recover.
  The Volcano isn't helping them either.
« Last Edit: December 05, 2021, 04:00:13 PM by Don R »
« Reply #147 on: December 06, 2021, 03:15:09 AM »
You can order now, 8 sets when I checked a few minutes ago.
https://www.davidsilverspares.co.uk/CB750K1-FOUR-1971/part_217723/
Online Don R
« Reply #148 on: December 08, 2021, 03:43:38 PM »
 I just saw that $1975, wow. Mrs. Santa says I've been bad, buying more bikes and speed parts. Not a good time for me to order pipes, but you guys need some. I get socks for Christmas.
« Last Edit: December 08, 2021, 03:52:06 PM by Don R »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Wow is right. I just bought a set of Delkevic pipes for my K8. For $1975 I could buy five sets of Delkevic pipes and have enough left over for socks!  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
