Author Topic: Quick K0 question please  (Read 890 times)
Offline Swoop
« on: May 19, 2024, 07:07:15 AM »
The rear winter bracket that bolts to the frame has a small spacer between it and the frame….anyone have the length? Do. Or pic?   Length is the most importantly that I need
Thanks
Offline BenelliSEI
  • 1969 cb750
Re: Quick K0 question please
« Reply #1 on: May 19, 2024, 07:16:11 AM »
“Winter bracket”?
Offline 69cb750
« Reply #2 on: May 19, 2024, 07:16:34 AM »
Riding a CB750 in the winter is dangerous.
Where is the bracket ?
Offline Swoop
« Reply #3 on: May 19, 2024, 07:31:47 AM »
Ooooops…..damn auto correct…..WINKER bracket
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #4 on: May 19, 2024, 07:47:51 AM »
Part image may help
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: May 19, 2024, 08:21:17 AM »
I’ll measure next time I am in the shop. J.
Offline Swoop
« Reply #6 on: May 19, 2024, 08:30:11 AM »
Like this one
« Reply #7 on: May 19, 2024, 08:33:02 AM »
 So, you need the size of the bolt spacer that goes through the rubber isolator?
https://www.partzilla.com/product/honda/90324-300-000?ref=3272bcd5c5bd6e3a109df61cadd8ff196c94cea3
Offline Swoop
« Reply #8 on: May 19, 2024, 09:15:44 AM »
Yes, we’ll put. I need to get the length and then see if I have one or can make something up.
Thanks
« Reply #9 on: May 19, 2024, 09:26:43 AM »
 The best part is that Honda used it on many models through the years and it's still available. They refer to it as 8mm, I'm not sure which measurement that is though.
 Click on it, and scroll through related fitment.
Offline ZTatZAU
« Reply #10 on: May 19, 2024, 10:06:21 AM »
Thanks
Here you go Swoop!
Honda p/n 90324-300-000, Collar 8mm
L=11.5 mm
OD=12.82 mm
ID=8.1 mm
ZT
Offline Swoop
« Reply #11 on: May 19, 2024, 10:20:03 AM »
Much thanks
Steve
« Reply #12 on: May 19, 2024, 11:34:24 AM »
There is shaped rubber mount as well
