Author Topic: The Quest for Brakes and Suspension: GSX-R Treats  (Read 65198 times)
Re: The Quest for Brakes and Suspension: GSX-R Treats
« Reply #351 on: July 29, 2014, 08:59:36 AM »
Seth,
I imagine you will get an appreciable power gain going from the Ural 750 to the R100 motor - an approximate 160% increase according to factory specs at the crank (70 vs 44).
I haven't had much experience with BMW flatheads, other than riding my buddy's R50/5.  It takes some getting used to when you rev the motor and feel the gyroscopic effect pull the bike to one side.  I'm sure you will feel it more with the larger R100 motor.  If you don't mind, post some pics of the BMW/Ural build as it progresses.
« Reply #352 on: July 29, 2014, 10:25:53 AM »
That gyro is mostly due to the output shaft being on the right side, tied to the right-sided final drive. Also, the cylinders are offset front-to-rear increasing this gyro. Like righthanded rifling in a pistol actually. That is why many of their bikes came with dampers I'm told. Deceleration and the gyro, hmmm, interesting steering effects.  :)
I wonder if the two-wheel drive of the side car combined with the weight of the side car balances that gyro effect.
« Reply #354 on: July 30, 2014, 12:29:45 AM »
Hahahaha. You know, it's not the size of the dog in the fight ...
Well that's true, but I wouldn't put it up against a pit bull to test the theory............. ;D
« Reply #355 on: July 30, 2014, 12:35:27 AM »
Seth,
And that's with a stock R100 engine, you can buy some excellent engine hot up gear from Europe that will double that figure for not a great deal of money. I thought about doing it to my second R100RS, but decided that it was easier to sell it and buy my K100RS, which is way quicker, and easier to live with. If I had a Urinal though, I'd do just what Seth is gonna do, and I'd work that engine over to within an inch of it's life.......... ;D
Offline sethdhawkins
« Reply #356 on: July 31, 2014, 09:28:03 AM »
It's a '96 Tourist, so the original motor was a 650cc! Yeah, I'm hoping the driveline will be able to handle it. I'm told that as long as I still respect it as a ural, I should be good to go.
Motor before cleanup.
Shiny ;)
I'll get to the barrels with the bead blaster when I go into the top end(s). I think I may start a project thread over on DTT for this...not sure how much interest there will be. I'm looking to still have this thing as an outside only rig, so cosmetics won't be as tight as previous builds. I'm mulling over paint ideas, and a general theme.
« Last Edit: July 31, 2014, 09:32:10 AM by sethdhawkins »
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
« Reply #357 on: July 31, 2014, 11:25:31 AM »
Please continue posting up some progress photos on this thread, if you don't mind.
« Reply #358 on: July 31, 2014, 09:40:37 PM »
Yeah, post about it here Seth, I don't like those DTT Wankers........ ;D
Offline Syscrush
  • Sold. :(
« Reply #359 on: August 04, 2014, 07:34:51 AM »
Not really great iphone photos, but I wanted to give you guys something before I went back to work. Honestly, I've pretty much just been riding the ural for the last three weeks ;) With the clip ons and the pull on the Mikuni's, the bike is pretty tiresome on the hands and forearms.
The best training for that is to ride more, not less!  This is a beautiful bike, you did a great job on it.
« Reply #360 on: August 04, 2014, 09:27:09 AM »
I wonder if the springs on the Mikunis can be modified or replaced with lower tension springs so it's not as much of a work out.  It would be a shame to have to swap out the RS34s, but you could always go to CRs.  Hey, it's only money, right?
« Reply #361 on: August 04, 2014, 09:42:27 AM »
I tried lower tension on the springs (you can unwind one of the springs), but alas, with the flatslides and the vacuum created by the engine, the slides will stick partially open on return.
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #362 on: August 04, 2014, 09:45:58 AM »
That sucks.  I had no idea the RS34s had what appears to be an inherent design issue.  I will be rethinking carbs for my second 750.  Maybe I'll do CR29s again.
« Reply #363 on: August 04, 2014, 09:57:17 AM »
1972-ish CB750K
1974 CB450
1974 CB360
Offline bjbuchanan
« Reply #364 on: August 04, 2014, 06:43:32 PM »
Be a pioneer!
http://www.dynoman.net/carb/keiFCR.html
I don't know much about your current carbs but I have a thought. Have you considered changing the leverage ratios, like increasing the size of the bell crank or at the handlebar grip with a different throttle tube?
I have seen where someone put fishing line around the nylon throttle tube to build up the diameter of the sleeve. That is a quick, cheap tweak to see if it begins to help at all
« Reply #365 on: August 05, 2014, 01:51:34 AM »
I've got a set of "as new" CR31's that I'd trade you for your Mikuni's Seth, if you're interested? Cheers, Terry. ;D
« Reply #366 on: August 05, 2014, 03:10:26 AM »
And I've got a pouch full of magic beans for trade ;)
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #367 on: August 05, 2014, 05:05:38 AM »
OOH OOH, I've got a bridge, wanna trade.... ;D ;)
« Reply #368 on: August 05, 2014, 10:20:14 AM »
Be a pioneer!
BJ,
FYI - Seth has a Motion Pro adjustable throttle, so I would imagine he has already tried the different throttle diameters as a "fix."
« Reply #369 on: August 05, 2014, 10:56:51 AM »
[/quote]
BJ,
[/quote]
Yup.
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #370 on: August 05, 2014, 10:56:57 AM »
[/quote]
BJ,
[/quote]
Yup.
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #371 on: August 05, 2014, 02:48:23 PM »
Seth, Mike Reick is the one to talk to, he runs these carbs and has done for some time, he's on holidays at the moment, I would definitely be talking to someone that knows these carbs well, they are used for racing and a heavy throttle is detrimental to throttle response..
« Reply #372 on: August 05, 2014, 04:21:25 PM »
Mick,
I spoke with Mike last year, actually. The carbs are dialed in, and damn near perfect. Bike runs like a monster. My single, and only fault on these carbs is the pull. I believe it's just the nature of the beast. If you google the RS's (34, 36, 38, 40's) throughout their applications (early gixxer, retro'd onto KZ's, etc.), you'll see the same complaints. I think the ticket is the flatslides with the roller bearings...buttery smooth (I'm hoping Don will take the financial plunge and get some racked). Others complain that the carbs are difficult around town, but I find them very easy, and they idle well.
Seth
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #373 on: August 05, 2014, 04:26:45 PM »
I wonder how different they are to the early GSXR1100 carbs, they were flatslides and smooth and light....?  I love light throttles and want to use a set of these, let us know if you find a solution, I think the bigger cam on the linkage is the way to go... ;)
« Last Edit: August 05, 2014, 08:16:20 PM by Retro Rocket »
« Reply #374 on: August 05, 2014, 04:29:38 PM »
I also prefer the light throttle. I'm at the second smallest cam in my package of four. Any larger, and it would make a 1/4 turn throttle feel stock.
1972-ish CB750K
1974 CB450
1974 CB360
