Author Topic: 7/32" clear fuel line  (Read 4680 times)
fendersrule
« on: November 06, 2013, 11:32:11 PM »
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: 7/32" clear fuel line
« Reply #1 on: November 07, 2013, 02:29:56 AM »
Is there a particular reason you want to go clear? If not, you can get the right size (5.5mm) from your Honda dealer.
Part #95001-5500160M - 5.5mm - Black
Cheers.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Dimitri13
  • 1974 CB550K
« Reply #2 on: November 07, 2013, 02:39:48 AM »
I got like 10 feet of clear 5.5mm hose on ebay for $15.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #3 on: November 07, 2013, 05:30:48 AM »
I get the 7/32nd clear fuel hose at a local MotorCycle shop here in Omaha. Check with your local small engine repair shop. I bet they have some they would sell you.  ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline andrewk
  • doin' it.
« Reply #4 on: November 07, 2013, 05:39:14 AM »
My experience with clear vinyl tube is that it becomes yellow and hard in about a year, maybe two.  OEM hose seems to stay pliable a lot longer.
If you end up searching local small engine shops, they will probably have tygon or something similar.  Better material than the clear vinyl, if you can stand to have green fuel lines. :)
Offline Toxic
« Reply #5 on: November 07, 2013, 05:53:36 AM »
Nice score .... I just paid $16 for two feet plus shipping.
I got fed up looking for a local supplier and it is literally the last thing needed on my project so what the H
« Reply #6 on: November 07, 2013, 06:51:14 AM »
Cheers.
5.5mm = 7/32" pretty darn close.
http://www.hamuniverse.com/antfrac.html
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #7 on: November 07, 2013, 07:50:30 AM »
I picked up 5 feet of 3/16" snowmobile fuel line at Canadian Tire last night for 3.99. They have other sizes too (including 7/32), but I wanted it nice and snug so as not have to deal with clamps.
3/16" --> 4.8mm
--Evan
1975 CB750K "Rhonda"
Offline evanphi
  • Apparently I'm an
« Reply #8 on: November 07, 2013, 07:52:20 AM »
Cheers.
[pedantic] 5.6, if we're going to one decimal... [/pedantic] :P
--Evan
fendersrule
« Reply #9 on: November 07, 2013, 07:53:03 AM »
I use 3/16 now. It just sucks trying to get it over fuel filters and petcocks. Even with heating and oiling, it's an endeavor. I'd rather go for 7/32, or 5.5. I believe that you still don't need to use clamps with these sizes.
Thanks for the feedback...I'll stay away from vinyl and keep looking. Seems like trying some local machine shops may be a good idea.
Offline dusterdude
« Reply #10 on: November 07, 2013, 12:36:17 PM »
Ive used 1/4 inch on mine for years
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
fendersrule
« Reply #11 on: November 07, 2013, 12:42:45 PM »
I've had 1/4" leak like a stuck pig on my '78 at the carb inlet...even with a clamp. I have to wiggle it just right so it doesn't leak.
Offline Dimitri13
  • 1974 CB550K
« Reply #12 on: November 08, 2013, 02:36:41 AM »
I believe I used 3/8" for the longest time. Very snug fit, no clamps needed. A pain to get off the petcock though, especially since I was always taking the tank off.
« Reply #13 on: November 08, 2013, 02:41:49 AM »
just use the proper rated black stuff,most off that clear rubbish always gives trouble,goes hard then thats why it wont seal on the barbs.
« Reply #14 on: November 08, 2013, 04:02:32 AM »
+1!
Offline OT7
« Reply #15 on: November 08, 2013, 07:03:40 AM »
I use Honda 5.5 mm ID black fuel lines.
« Reply #16 on: November 08, 2013, 07:19:38 AM »
+1!
+1
« Reply #17 on: November 08, 2013, 07:56:03 AM »
+1!
+1
But the clear (or tint) is so cool. You guys are no fun!    8)
« Reply #18 on: November 08, 2013, 12:35:23 PM »
ive put clear on overflows.
