Author Topic: So much for "clean the carbs and go"... Look at this oil  (Read 3326 times)
Offline fmctm1sw
« on: November 10, 2013, 07:22:59 AM »
I got around to looking at an old Silverwing I have.  My first sense something was wrong was the sound of the starter.  It made squealing sounds like a stuck pig when I pushed the button and didn't turn the motor over.  I got the motor to turn over when I pulled the plugs.  Then I checked the oil...   Yeah, take a look.  This went from short term to long term...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline dhall57
Re: So much for "clean the carbs and go"... Look at this oil
« Reply #1 on: November 10, 2013, 08:03:37 AM »
That doesn't even look like oil any more :o Looks like snot out of your nose. That's horrible!!
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
    • http://forums.sohc4.net/index.php?PHPSESSID=89jfrv7ito6t4vgof8bagfvlv1&/topic,60973.0.html
« Reply #2 on: November 10, 2013, 08:06:50 AM »
wont happend on a aircooled... ;)
Offline heffay
« Reply #3 on: November 10, 2013, 08:10:45 AM »
I've seen a number of crankcases with oil that looked like that... all caused by coolant in the oil.  You may have bigger problems than you think.
If it is gas that seeped down the cylinder walls from sitting over time, it usually doesn't have the distinctive milky look, it just looks like watered down oil still, in my experience.  When we bought my wife's Kaw EX500 it had an extra gallon of gas in the crankcase that seeped in from a leaky petcock and overflowing carb bowl.  Looked like oil, did NOT smell like oil.   ;)
Offline madScientist
« Reply #4 on: November 10, 2013, 09:56:44 AM »
Oof...so much for the crank and rod bearings...With that much snot in there those suckers are likely gone or will be soon.
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
« Reply #5 on: November 11, 2013, 01:47:51 PM »
Winter project coming up
« Reply #6 on: November 11, 2013, 02:10:15 PM »
Water in the oil.  Does it smell like anti freeze?  If just water, maybe condensation build up.
Offline fmctm1sw
« Reply #7 on: November 11, 2013, 04:04:06 PM »
I can't quite place the smell.  You know what it makes me think of though?  My Dad had a Cadillac Sedan deville that got flooded in the 1977 Johnstown flood.  That's kind of what it smells like.  Like old wet carpet maybe?
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline MoMo
  • Ride like you're invisible
« Reply #8 on: November 11, 2013, 04:51:43 PM »
Notorious for water pump mechanical seal failure is the Silverwing.  Antifreeze empty or full?...Larry
Offline fmctm1sw
« Reply #9 on: November 11, 2013, 05:01:52 PM »
Empty.  But given the neglect of the bike, I didn't want to make assumptions.  I had a CX500 that I did the water pump seal on.  Looks like I'll have another chance to do one...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline MoMo
« Reply #10 on: November 11, 2013, 05:06:58 PM »
I had a thread bookmarked where someone had a step by step photo essay on using a Yamaha mechanical seal to replace the Honda(which is about the only weak link on those bikes, other than acute lack of power and obesity).  I still have a Silverwing that was my daily rider until I got the PC...Larry
« Reply #11 on: November 11, 2013, 07:41:02 PM »
I have a CX500.  When the mechanical seal fails, doesn't it pump the water overboard, rather than into the motor?  That's what mine did.
Offline MoMo
« Reply #12 on: November 12, 2013, 12:33:15 AM »
that is the more likely scenario TT.
 If I had that GL I'd drain all that crap, flush the motor with kero, add oil and see what I have. Silverwings are almost bullet-proof and can take a ton of abuse and keep on ticking...Larry
« Reply #13 on: November 12, 2013, 08:33:37 AM »
+1 I agree w/ MoMo
Offline fmctm1sw
« Reply #14 on: November 12, 2013, 04:37:50 PM »
Larry, I saw that write up on the Yamaha seal.  That's how I did mine.  Worked perfectly.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline fmctm1sw
« Reply #15 on: November 12, 2013, 04:41:38 PM »
+1 I agree w/ MoMo
TT, there is a weep hole on the bottom of water pump cover.  In case of leaks, that's where it should come out.  I may consider just trying to flush it out (nothing to lose I guess) but I'm concerned about the action/sound of the starter.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #16 on: November 12, 2013, 04:48:08 PM »
When I got mine, the starter was frozen, because of the weeping mechanical seal dripped right on it.  I had to rebuild that first.  Consider that your starter may be the source of the noise related to the starter.
